How much current on +5V serial port of Multi4? - RC Groups
Feb 28, 2017, 01:45 PM
LittleMo's Avatar
Question
The Multi4 has a 3-pin serial port connector with ground, +5V, and signal. How much current can the +5V connector supply?
Thanks!
Mar 01, 2017, 07:02 AM
ggcrandall1's Avatar
Thanks!
That port is for power to the FUIM3 data cable. I doubt you can use it to power anything else.
Glen
Mar 01, 2017, 08:04 AM
Glen
That is correct. It will only provide a few mA and the voltage drops quickly with load.
Mar 01, 2017, 09:08 AM
LittleMo's Avatar
I know what it's for but that wasn't my question. How much is a "few" mA?
Edit:
Briefly looking at the circuit it looks like that might be the main 5V power rail for the whole device in which case it seems likely it can supply a reasonable amount of power. I can't find a good picture of the board online and I don't really want to dissemble the whole thing to find out where the regulator is which is why I was asking before resorting to such methods.
Edit again:
Looks like LM78L05ACM so 100mA total supply. Not sure what the charger (display, etc) draws though so not sure how much current is left over.
Mar 02, 2017, 09:37 PM
Edit:
Edit again:
It is only tested to support about 10mA which is required by the FUIM.
