Feb 26, 2017, 09:19 PM
New Product
Micromake 3D Printer Linear Guide Auto Leveling Metal Printer injection version
Good News:
with the printer, you can get 8G sd card and test material and the hex tool.
Notice:
1.Customers have to know the import laws in your country before ordering; free shipping doesn't include the import tax.
Check before ordering !
2.After make an order, please leave an message about the declared value in invoice.
3.The steppr motor has update to all black version.
4. Because of the various version and big difference of Mac and Linux, so we can only provide the related drive, we can't
promise any version of mac and linux will be work with our printer, we suggest to use Windows system, no need drive and
you can use directly.
Features:
1.All injection molding non-standard parts
2.Black oxidation aluminum profile
3.High performance control board
4.Double air duct effector
5.High intensity extruder
Technical Specifications:
Layer resolution of 50 microns.
MAX Printing Speed: 150 mm/s.
Build size: Maximum 180mm*300mm,but with 180mm you need adjust many times, usually the max diameter is 160~180mm,
and the max height is 300~320mm.180mm*300mm is the limit.
Full Metal E3D V5 long distance J-head nozzle Extruder.
Material type: PLA, ABS, wood, nylon
Material specifications 1.75mm in diameter.
Positioning accuracy: XYZ:0.01MM
Printing Color: Single color.
Nozzle diameter: 0.4mm (customized 0.3mm/0.2mm).
Recommended extruder temperature: 240C
Best ambient temperature: ≥25C.
Power requirements:110V~220V,60W
Connection: SD card or USB.
The file print format: STL,G-Code.
Compatibility: Windows,Mac
Device Package weight: Pulley Type about 7.5 kg ,Linear Guide about 8.5.
