That's what I did on one of the protos Stuart sent me. I only had a 6ch rx on hand. worked fine...adds a bit more drag, but nothing a little more throttle cannot overcome!
So is the lower wing compatible with v1 Trojan? Not a big fan of yellow . I like the red and white much better but would like the new features. |
LURCH |
https://hobbyking.com/en_us/catalog/...-parts/id/7037 |
Ok found it. Took me some looking as I am using the mobile app. Still don't see the v1 prop adapter and prop. Im assuming that when I finally break my last prop I will need to upgrade to this style setup to use new prop. Is the v1 prop a 10x7? This new one is a 10x6. Different power system?
Besides, the accessory bag has some sort of paper strip. (waxed or decal paper of sorts, even shown in the manual). Anyone knows what it is for? |
So have you figured out what is this paper for? Thanks. |
No idea what the paper is for, maybe Rob can tell us? |
Thanks that's how I set it up so should be ok. Its as forward as it will go I think.
Ok so did a quick maiden today, unfortunately it was very windy. I didn't quite get the CG right.. still need to move the battery forward under the ESC and into the cowl. So I was pretty lucky to do some laps and bring her down safely Its extremely powerful with 4s (my first 4s) and coming from the Tundra very agile and nimble! I tested the sound card from my Texan, sounds good given that both are 9 cylindar radials.. but the motor itself is quite loud and makes a nice noise. Will try for calmer weather tomorrow
https://www.facebook.com/david.bello...4684004321871/ |
