GEPRC GEP-LX Leopard FPV Racer Thread - RC Groups
Feb 25, 2017, 08:11 AM
nitbeat's Avatar
New Product
GEPRC never stop making new frame designs, it seems like FPV Racers are heading towards
a slick, minimal design with easy access to electronics.
GEPRC GEP LX Leopard LX4 LX5 LX6 195mm 220mm 255mm FPV Racing Frame 4mm Arm With PDB 5V & 12V
http://www.banggood.com/GEPRC-GEP-LX-Leopard-LX4-LX5-LX6-195mm-220mm-255mm-FPV-Racing-Frame-4mm-Arm-With-PDB-5V-12V-p-1134161.html
Baby Leaopard Frame ( 3 Inch )
GEPRC Sparrow GEP-MX3 GEP-MSX3 139mm 145mm Carbon Fiber 3mm Arm FPV Racing Frame
https://www.banggood.com/GEPRC-Sparrow-GEP-MX3-GEP-MSX3-139mm-145mm-Carbon-Fiber-3mm-Arm-FPV-Racing-Frame-p-1168348.html
this frame is a beauty !
Description
Brand: GEPRC
Item: LX Leopard Racing Frame
Material: 3K carbon fiber & #7075 aviation aluminum
PDB: 5V 3A & 12V 0.5A BEC
Screws: YFS 12.9
Thickness of frame arm: 4mm
Thickness of side plate: 2mm
Thickness of other plates: 1.5mm
Wheel base:
LX4: 195mm
LX5: 220mm
LX6: 255mm
Weight:
LX4: 109g
LX5: 114g
LX6: 123g
Features
Strong aviation aluminum #7075 CNC body.
3K high strength carbon board to ensure that the framework is strong.
Integrated aluminium alloy structure to steady the 4 frame arms.
4mm thickness and 13.5mm width frame arms' design.
True "X" frame, suitable for racing and freestyle flying.
Adjustable camera angle, adjustable 60 degrees.
Use YFS screws.
With 2 camera side plates, supports HS1190, HS1170, Swift, OVL camera.
With a XT60 PDB integrated BEC (5/12v output)
It does resembles a few frames that are already in the market such as the DQUAD obbsession
nitbeat's Avatar
reserved
Feb 25, 2017, 11:47 AM
Fauropitotto's Avatar
The Clone is strong with this one.
Innovative? Really?
I guess they couldn't help but copy the design ideas from DQuad's Obsession frame.
Clones have their place, but to claim "innovation" is a bold faced lie.
http://www.dquad.nl/Obsession.html
First seen here on November 29, 2016 ->https://www.facebook.com/DquadFPV/
https://www.readymaderc.com/store/in...oducts_id=6467
Feb 25, 2017, 03:29 PM
nitbeat's Avatar
Originally Posted by Fauropitotto
Innovative? Really?
DQuad's Obsession frame is definitely a pioneer pushing forward to an intelligent minimal design !
New frames take different inspirations of elements all the time man, I'm glad dquad obsession created this amazing frame,
and showcased this great design and ideas.
It's natural to take different ideas and elements from other frames it happens often.
Feb 26, 2017, 03:14 AM
Innovative? Really?
Definitely a clone, but not nearly as nicely done. I see nowhere for a lock nut inside the aluminum brackets, so they are threaded? Meh, i'd still buy the dquad.
Mar 13, 2017, 10:41 AM
nitbeat's Avatar
wowowww !! new pictures just release and a name: Leopard
Mar 16, 2017, 06:03 AM
sharonx's Avatar
Looks Good, it's on my wish list for sure...
Mar 16, 2017, 07:31 AM
why doesn't it ever just work?
WickedWingman's Avatar
they definitely took some design cues from the obsession, but i actually like some of the improvements they made. while better thought out than the dquad, there's still plenty about this i don't like. WHEN these things break, i have a bad feeling it will be total annihilation. the arm will break and the aluminum will twist because of the way everything is tied together. the electronics stack should be relatively safe tho.
Mar 19, 2017, 10:37 AM
nitbeat's Avatar
I was surprised how weak expensive frames that I bought in the past were, and sometimes the cheaper ones may surprise you.
It really depends how lucky you are when you crash, how you crash can make a difference.
I use GEPRC frames for a while now, and they are not amateurs, they invest in their kits and frames.
Hope this one will be a success story
Mar 25, 2017, 10:53 AM
Talisman013's Avatar
Did a quick unboxing and assembly video. I love this thing so far. I also have the hawk.
GepRC - LX6 Leopard (20 min 48 sec)
EDIT: Video fixed.
Mar 25, 2017, 03:16 PM
nitbeat's Avatar
https://m.youtube.com/watch?v=nHkdZGV3yZk
This video is unavailable.
After you fix the video issue - Use this version of the link: "https://www.youtube.com/watch?v=nHkdZGV3yZk" so we could play it in the post itself
Mar 25, 2017, 05:23 PM
IronManFPV
SevenSonics's Avatar
I saw a video on youtube so I believe its yours. However I don't know if ordering straight from geprc will be better than ordering from banggood.
They still dont have it on stock.
Mar 26, 2017, 09:26 AM
nitbeat's Avatar
New pictures of the GEP-LX
Mar 26, 2017, 11:18 PM
fixed, ty.
Mar 26, 2017, 11:30 PM
Some pics of the build:
