The 6A MX-3 was going into LVC ( shipped with LVC set at 3.1 V) because of the small gauge wire I was using between the Battery and the ESC. The wires were 2" long on the + and - side. I reconfigured the system so that the battery plugs into the ESC ( see the picture) without any wires. This kept the voltaget o the MX above 3.1 V and that allowed the system to run 5 minutes vs 2 min. |
Reason: Tried to remove 1st picture can't???
Thanks George, I've seen that setup several times including on Dave Lockharts Victory, in person.
Mine works fine with some really fine wires BUT your findings and the fact that other are going direct with heavy connections tells me I should see if I can determine how much I'm loosing. I have no issue with flight time but anything that keeps me away from an LVC event is to be considered. I' will have to check but pretty sure my LVC is 3.0. BTW, this is from Alexy's thread- "16 propellers and system AL 11-12 min fly with 120 ma battery." I'm not getting this much time but it seems I'm getting a good deal more than you, |
The programming cable can be used while the ESC is mounted in the plane. You only need to add a small connector to the signal wire. Here are the steps for programming:
Finspeed,
Had a great time at our indoor session yesterday. 10 flights were made by several pilots. Big smiles on their faces since they fly only Clicks and this setup blows their minds. All flights were about 5 minutes 20 sec with batteries showing 9 to 15 % when placed on charge. I won't be getting into programming the ESC LVC to 3.0 volts for now. i'm happy with the flight time for now. Donatas had been watching the "short flight" saga and after watching the video suggested that I burn holes in the full drag brakes to reduce some of the drag. He mentioned that less drag would allow the plane to fly a little faster in the up line and I assume that less drag will increase flight times a tad also. Cutting holes will be the only change made to the plane for next week. Thanks again for getting involved in this problem. |
Pete |
The battery tester I use is this one from WestMountainRadio. https://www.dxengineering.com/search...rder=Ascending I got mine when they first came out, maybe 8 or more years ago. At that time it couldn't test at super low discharge rates, so I paid them to modify it so it could do low rates before shipping it to me. I believe that it now can do the low discharge rates as a standard feature. I also find the discharge tester useful for batteries which might be getting a bit old and feel to me like they are not performing. I put them on the tester and it takes the guesswork out of it. If the battery of interest isn't up to snuff any more according to the test, it gets disposed of. I find this a very useful piece of equipment. I don't know if there are other battery test products out there. But, this one does everything I need it to do. |
![]() Yup, the propulsion system is a major portion of the price of entry for one of these planes. |
Got 6 flights in today. Two flights recorded were 5 min 45 seconds with 9 % and 5 min 51 sec with 8% on cells when placed on charge.The cells are 120 Hyperion G3. The Arena and my basement are cold so I charge the cells before flight and warm them with hands and mouth
![]() Also, made the holes in the drag brakes. Hoping that a contest flier shows up during the holidays for some evaluation of how it flies. For me, it flies great! Would have tested the 160 Hyperion G5 cell but the pos lead to the pico boost broke. Back at it in 2 weeks. |
George, Lipo temp has a very large impact on their performance.
Recent research has proven that issues with degradation can be mitigated by using elevated temps with modified chemistry. Super high rate charging is being done by having heaters IN cells to get them up to 160 deg, which allows charge rates of 10-20C with no degradation. Same is true of discharge, but of course its a thin line between max performance temp and thermal runaway. Unfortunately our "standard" lipos do not like temps over 115 deg and for longevity should be used at 85 deg. https://batteryuniversity.com/learn/...w_temperatures For our use I believe cells at 85-95 deg gives the best power good. FYI, there is a reason Hyperion sells heated Lipo bags. You will love the G5 160s, with an Ermolin drive they nearly double flight time over 120s. G7 180s are insanely punchy the whole flight but when they go, there is nothing left so set your timer. The increased weight is not noticeable to me. |
