This thread is privately moderated by phil alvirez, who may elect to delete unwanted replies.
Feb 22, 2017, 04:46 AM
Cool
you are just learning...
22 feb 2017
the learning curve
there are no failures: when something does not work, you learn that. it is not that you failed. it is 1 thing that does not work. thats all. you are learning! now that you learned it doesnt, try again in a different way. until it works.
in other words: life is a series of attempts to get something. until you do (read comments).
Feb 23, 2017, 03:18 AM
eagle60's Avatar
In few words: experience is a long serie of mistakes
Feb 23, 2017, 11:21 AM
mistakes or learning
psychologycally, it is a negative way of seeing it. if you face it that way, you are acknowledging that if some thing that you try does not work as expected at the first attempt, it is a mistake. you are failing. and that leaves a scar in your subconscious mind.
but if you see it as a logical way of learning, it is a positive attitude. you are just learning! that is the way of learning.
it is an attempt. like learning to walk: 1 step at a time, and then try to learn something from that, so next try another way and compare.
Edison did not fail or made over 6,000 mistakes before inventing the incandescent lamp. each time he (and his crew) tried, was learning that it was not what they needed.
but its up to you. you decide. you go through life making mistakes, or you through life learning. your choice
