This thread is privately moderated by demondriver, who may elect to delete unwanted replies.
Feb 22, 2017, 02:42 AM
Up-Out-&-Gone
demondriver's Avatar
Cool
RC MineCraft Seagull
Build Your own RC Minecraft Bird (5 hr 57 min 10 sec)
Hi DemonDriver Aka Christopher Here & I want to share with you How to build your very own Seagull-Bird from the Video Game Minecraft!
I give you basically the entire build and then the maiden flight at the end.
My Minecraft Seagull is so easy to build ANYONE can build it!
Here are the parts for this Minecraft Seagull:
3-4 20" Inch Long carbon fiber rods.
Lite-weight Cardboard
3-4 large sheet of Depron or equivalent foam
1 30-60AMP ESC speed controller
1 7-11Volt lipo Battery
1 750KV or up to a 2000KV brushless out-runner motor use a motor around 1-2 inch in diameter . . .if it too large it will make your plane too heavy!
3-4 11-20 gram mini servos, you can use heavier "standard" servos buy you must increase the wingspan larger than 48 inches to 96" inches
1-6, 8 or 10, 12 inch prop
No landing gear required . .but 2 1 or 2 inch diameter foam wheels can be used
Plastic hinges and speed connectors
I use a Futaba 7CAP 2.4Mhz Radio and FASST RX for this plane. But use any Radio you want.
Latest blog entry: RC 737 Max 7 Maiden flight!
