Jun 08, 2017, 09:24 AM
ReTechNL's Avatar
RunCam Split
Split RunCam 3 for FPV
SKU: SPLIT
Weight: 21.00 Grams (0.74 Ounces)
Instruction diagram
Module connection diagram
Replaceable Lens
Unit of length: mm
Parameters
FOV Angle of Field FPV FOV 130 / Recording FOV 165
Video Resolution [email protected] / [email protected] / [email protected]
Video Files MOV
Image Resolution 2 Megapixels
TV Output NTSC / PAL Switchable
Real-Time Audio Output Yes
Interface Micro USB / UART
Max Micro SD Card Supported 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II)
WiFi Module Support (Removable)
Dimensions PCB 36*38mm / Lens Module 22*20mm
Power Input DC 5V
Working Current 650 mAh
Weight 21g
Documentation:
English: https://www.runcam.com/download/spli...m-Split-EN.pdf
Deutsch: https://www.runcam.com/download/spli...m-Split-DE.pdf
Chinese: https://www.runcam.com/download/spli...m-Split-CN.pdf
More information:
http://shop.runcam.com/runcam-split/
https://www.rcgroups.com/forums/show...just-announced
Jun 13, 2017, 11:08 AM
DOA Runcam 3
Long story short. I got a friend purchased a brand new runcam 3 from HK on his trip. I would have purchase it from usa if they are shipping to USA. I was excited to receive it. BUT it have no power. It only power up on USB cable. Power will go off as soon as I unplug the usb cable. Also the runcam 3 does not detect the sd card.
I contacted Runcam Customer Support for help or warranty. I was told to return it to my re-seller. That wont happen. Now I am stuck with a bad Runcam3.
Since I have no warranty. I decided to open it and see if lipo are unplug. I found that the lipo was shorted out and burn out wire. Brand new Runcam 3 out of the box.
Jun 13, 2017, 02:25 PM
Fauropitotto's Avatar
Why didn't you have your friend test the camera before he left HK?
Jun 26, 2017, 01:45 PM
Originally Posted by Gouada
Yes. In the other RunCam 3 thread I wrote about my experience of putting it into time lapse mode (w/o charging at the same time) and having the thing get so hot after 25 min it wouldn't turn on until I put it in the fridge.
Hi, exactly, it's insane - I just got my RC3 and I timelapsed maybe for 10 minutes and the camera was like a hot bun right from the oven and half of the battery gone Not happy 'bout that at all
I will try to turn off WDR, as it's stated in the manual:
NOTICE: When capturing video with WDR and at high frame rates in warm ambient temperatures, the camera
may become hot and use more power. When using WDR, please capture shorter video clips or choose lower
frame rates, and/or limit your use of features that increase power consumption in the RunCam App.
Jun 26, 2017, 01:47 PM
Sorry, one more thing: is there a way to start time-lapse video recording without the app? It somewhat cumbersome to use the app :/
Jul 10, 2017, 09:28 AM
I am not so proud owner of the RC3 as well.
Here are my issues with it.
1. Video quality - the bitrate on it sometimes is 30Mbps most time it's below 30 which make fpv video look like crap.
2. I do not expect the GP sound here, but what is the story with the left / right switching ??
3. It's lacking and kind of "superview" like feature, which is also down side. I have "superview" on my Xiaomi YI for that matter.
On the plus side:
1. The best form factor.
2. WDR .
3. Price.
Aug 19, 2017, 11:41 AM
Originally Posted by RunCam
Sorry, we don't have the tempered glass protectors.
But we have the mounting frame http://shop.runcam.com/Mounting-frame-for-runcam-3/ and the waterproof case http://shop.runcam.com/waterproof-case-for-runcam-3/
Hello, what happened with the mounting frame link to your website? Can it still be bought somewhere? Id buy two...
May 15, 2018, 02:05 PM
iksobarg's Avatar
Hello, my RC3 microphone intermittently cuts off during recordings, that is it cuts off for maybe 10-15 secs then comes back then 30 secs later it cuts off again, and again... video is fine... any insights?
many thanks!
