Product: | Hitec Phantom X4 |
Retail price: | $214.99 |
Input Voltage: | AC 100-240V |
Charge Power: | 100W- X4 |
Charge Current: | 6.0A |
USB Output: | 5V/2.1A -X2 |
Modes: | 3 -Charge, Storage, Cycle |
Size: | 255 x 142 x 180mm |
Weight: | 3.22kg |
The Hitec Phantom X4 Multi-Charger is a simple to use, fully automatic, smart charger for your DJI Phantom 3 and 4 smart battery packs. With Charge, Storage, and Cycle modes, it will be your new favorite charger for your DJI Phantom. Let's check it out!
Hitec Phantom X4 SMart Battery Charger - RCGroups Review (4 min 3 sec) |
The Phantom X4 comes with the charger, power cord, USA charge cable (micro B), and remote controller charging cable (x2). Every thing you will need to charge 4 smart packs, and two controllers simultaneously.
The Hitec Phantom X4 Multi Charger is equipped with outputs to charge 4 battery packs, 2 controllers, and 2 USB devices all at the same time! These features should keep you powered up at the field all day long.
Using the Hitec Phantom X4 is super easy and you will be on your way to fully charged packs in no time at all! Let me run through the operation for you so you can see how simple it really is.
Easy Peasy!
With its simple to use set-up and multi-purpose charger modes, the Hitec Phantom X4 Multi Charger is quick to become your go-to DJI Phantom 3/4 charge station. Well done Hitec! Get out and pick yours up today, you won't regret it! ~Mean Joe
You need the optional cable adapters.
Better to buy the SkyRC 4P3 charger, which is the same but includes four of the adapter cables. http://www.skyrc.com/index.php?route...product_id=228 |
Input voltage is not mentioned. Can it run off 12v?
Phantom Hitec X4 Smart Charger
Greetings. In reading the info (ad?) about the Phantom Hitec X4 Charger one of the features they comments about is the ability to cycle a Lipo battery? Am I missing something? I know of the need to cycle Nicads to overcome what we used to refer to as "memory," but is there something now going on about memory in Lipos that I must have missed somewhere in the last 15 years or so?
Thanks. |
The brains inside phantom and inspire backs transmit real time data to the GO app and give the flyer full time feedback regarding true (close enough) real time capacity and flight time left, when to trigger return to home, alert the flyer that he/she is nearing bingo fuel, and also real time cell levels. |
Dave |
Latest blog entry: Flying Log Book
Phantom 4 battery adapter cable
Where could I get the optional Phantom 4 Smart Battery cable, part# 61116?
Where can I get the optional Phantom 4 battery cable, Part#61116?
