Jun 24, 2017, 04:54 PM
RocketMouse's Avatar
Some more questions please:
What will happen if I set 16 PPM channels but will feed only 12 from the radio?
What is the minimal step for hopping frequencies?
Jun 25, 2017, 02:02 AM
Originally Posted by RocketMouse
Yes, it works now like a charm! And the delay is really small! That's wonderful!
Thank you.
It's amazing how it's easy to make an LRS now! (Or even one can say ULRS)
I'm waiting hard to test it now.
BTW, may I also suggest another nice future - automatic power control based on RSSI.
Good
Regarding auto piwer control i can do it...
Jun 25, 2017, 02:04 AM
I don't try but why do you want to do that? It will be better to set correct value to avoid sync problems. Btw you can set let say 12 channels in TX and 16 in RX and it should ne fine.
Jun 25, 2017, 02:21 AM
That's good because I want to set 12ch for TX and 13 for RX and put RSSI to 13ch.
It's a pity that APM 2 doesn't support RSSI over PPM.
Jun 25, 2017, 02:37 AM
Regarding freqency hopping you can set anything you want but remember that bandwidth is 250kHz an chanells should not overlap to avoid freq hopping sync problems. I need to add chn number to frame payload to make possible using overlaping freq. and keep everything in sync.
Jun 25, 2017, 03:25 AM
Thank you, got it.
One more feature - Led blinking frequency according to txMaxPower value to indicate current transmitting power level.
Why is it transmitting when there is no PPM-in? I believe it should not transmit anything in this case and RX should switch to FS.
Jun 25, 2017, 05:02 AM
Thank you, got it.
Because except ppm values you can tramsmit serial data from groud to uav. 3 byes in every frame.... See documentation.
Jun 25, 2017, 05:41 AM
Sure, I've seen it, just forgot. A lot of info at the same time. Sorry.
What these 3 bytes can be used for?
Can you please also comment on analog RSSI out?
Jun 25, 2017, 06:09 AM
3 bytes could be used for anything... Especially for custom projects... For mavlink are useless what do you want to know about analog rssi? Analog output is present on the same pin you use for connecting button...
Jun 25, 2017, 06:13 AM
"PWM RSSI signal on external pin available. It’s 1.2kHz PMW signal which could be used together wits simply RC filter output analog RSSI voltage"
Jun 25, 2017, 06:35 AM
Did I get it right - it's PWM RCCI at M1 pin, but to convert it to Analog RSSI it's necessary to connect RC filter like that:
Jun 25, 2017, 07:07 AM
Yes
Jun 25, 2017, 08:03 AM
Great, I'm ready to fly!
Jun 25, 2017, 08:39 AM
God bless you
Jun 25, 2017, 10:15 AM
Remember about fail save....
