Hubsan H501A, WiFi based but smart (in very early construction) - Page 41 - RC Groups
Jun 06, 2018, 11:39 AM
John Luciano's Avatar
I don’t fly mine with that controller. That is blue tooth. 1st make sure your phone is blue tooth. And make sure you have BT activated. Turn on the trans .. look in Blue tooth for the drone. Also scroll through the AOP looking for the “ use transmitter or use controller. This is in the set up
Pages. When you do that the Blue Tooth should show up on the phone to be selected. The Tran blue light stops flashing.
It may take a few times to get it to connect.
Jun 06, 2018, 06:42 PM
Originally Posted by frits183
Well I also have received the HT011A transmitter.
There is no manual with it and I can not find it on the net.
I have followed the instructions from QC
https://youtu.be/KUPrJrMnw18
But the 2.4G will flash (occasionally)
And not stay on, so I presume there isn't a connection!!
How can I activate it to work.
Did you bind it?
Press and hold "Bind" and press "power" on the HT011A then turn on the drone. That's what all the videos show.
Originally Posted by John Luciano
I donít fly mine with that controller. That is blue tooth. 1st make sure your phone is blue tooth. And make sure you have BT activated. Turn on the trans .. look in Blue tooth for the drone. Also scroll through the AOP looking for the ď use transmitter or use controller. This is in the set up
Well, after looking at that and other videos about HT011A, I got an impression that nobody actually knows how the thing works.
As I did not get a definite answer from Anne, I'm beginning to think that Hubsan knows neither (no offense Anne).
From what I gathered about HT011A so far (I do not own one):
- it is not a BlueTooth controller
- it does turn on the 5.8GHz VTX on-board the drone if it is bound through 2.4GHz (this is the info Anne could not confirm but several videos clearly show it)
- the built-in WiFi relay behaves the same way as the "old" external WiFi relay - it is for connecting a phone to the drone (some reviewers suggested that HT011A is controlling the drone via WiFi relay, what I find unlikely based on what I saw in their and other videos)
Basically, HT011A combines the HT005 relay and the H907A controller (plus GPS and better sticks, minus LCD) into a single unit.
And it makes the drone turn the VTX on.
Jun 06, 2018, 08:03 PM
I fly mine using the 502S controler. It shows camera FTV on it's screen. I did not try the range . Can u use the HT 011A controler with out the phone ? My 507A has a controler and needs the phone. That is the explaination I gave you since it looks like a similar set up!
Jun 07, 2018, 03:12 PM
The controller you have for H507A is likely the HT009 - which is a BlueTooth "gamepad".
Ht011A has no BlueTooth.
And yes, HT011A should be usable without the phone.
Jun 08, 2018, 01:10 AM
Thanks for the answers Folk's.
Lucky I am still learning and not flying outside my L. O. S.
Sinds my H501M don't fly properly, offerd Anne me a H501A BNF.
But it came without a controller so I hoped the HT011A would be a good solution.
But sinds there isn't a propper manual I am a little bit lost
And happy with your feedback.
Meanwhile I found this,
https://ae01.alicdn.com/kf/HTB1.Tpkl...dq6zeSpXaA.jpg
Jun 08, 2018, 01:16 PM
The HT011A is usable without the phone. Bind the aircraft to the transmitter via the 2.4 connection and you've got a standard UAV protocol connection.
Jun 08, 2018, 01:19 PM
Depends on what you are asking about. A good majority of the functions available on the transmitter we know how to use at the North American office. What specifically would you like to ask about?
Jun 09, 2018, 01:10 AM
A manual and or instructions from you folks 4 the customers who interested to buy or already bought the HT011A.
So we know what to aspect and how it works with
the 501M. (Wi-Fi only)
the 501S/S (2.4g/5.8g)
the 501A. (Wi-Fi / 2.4g / 5.8g)
And Ofcourse the other one's
Jun 12, 2018, 05:28 PM
Such a manual is already being written and translated. It will be released along with the product when mass production begins.
Jun 15, 2018, 02:49 AM
Its already listed as a spare part.
http://www.hubsan.com/na/index.php?m...roducts_id=853
Jun 15, 2018, 10:38 AM
Anne, the question was whether HT011A turns on 5.8GHz VTX onboard the H501A.
Various YouTube videos show that it apparently does.
Can you confirm that, please?
Jun 18, 2018, 05:36 PM
I confirmed with R&D the following. Please note that it is not the HT011A in particular that does this, but whether or not certain frequencies have been initialized.
If the 2.4G frequency connects, the 5.8G will automatically turn on as well.
With the latest firmware, initialization of the WIFI should also be accompanied by the 5.8G powering on as well. Keep in mind that I have not yet tested this particular case successfully. But R&D has said that they've made this feature available.
Jun 18, 2018, 06:09 PM
Thanks, Anne.
I have been suspecting that to be so but this info makes it official.
That is absolutely fantastic news!
Just to be sure - can you please tell what version exactly would that be?
Yesterday, 08:39 PM
KC5UH transmits -------->
ham2405's Avatar
Fly away
I took my 501A out with an H901A controller that I just got in a 502S deal in which the quad is broken. Long story shortened, about 3 minutes into the flight, the quad decided it would go where it wanted! It flew behind my tall tree towards the neighbors tall trees behind my house. My wife who was out front with me said she thought she heard it hit something.
So,
Llucky #1, the quad was only 13m high so it did run into the trees.
Lucky #2, when it hit the trees, it did not get stuck but tumbled to the ground.
Lucky #3, when it hit the ground, nothing appears to be damaged.
Lucky #4, when I went around to the neighbors, they had already found it.
Lucky #5, the quad was dead, no LEDs. But when I got home and checked the battery, it was at 7.93V!
I plugged in the battery and began to check it out, trying to find a clue to what happened. After a couple of minutes, I got a clue. Normally, I can get solid GPS lock when a quad is sitting on my workbench. This time the Lock was intermittent, showing 0-10-0-11-10-0 and continuing. That explains the quad ignoring the RTH switch - it had no GPS lock and it went behind my tree before I could get oriented to fly back manually.
Hey, Anne, what do you think about this?
Yesterday, 08:49 PM
1st open It up check the plugs. Make sure they are in solid . Also peal Back the black GPS cover and check those connections
