This thread is privately moderated by choochoo22, who may elect to delete unwanted replies.
Feb 15, 2017, 08:56 PM
Rick
Explanation of PWM, PPM, CPPM, and S-BUS signals
The attached PDF contains an illustrated description of some common encoding methods used in the hobby. It probably has more detail than most people need but you may find it interesting if you enjoy knowing how things work.
Some technical background is required to follow the descriptions. If you know that a millisecond (ms) is 1000 microseconds (Ás), that analog refers to continuously variable data like a speedometer with a needle while digital refers to discreet values like a speedometer with digits, and that digital data is represented in binary, then you probably know enough to get something out of this.
Rick
