Feb 15, 2017, 01:51 PM
Question
Frsky X8R Antenna Replacement
I have had some difficulty replacing the stock Frsky antennas on the X8R receivers. There is some yellowish-brown cement holding the snap-on ends of the antennas. I spoke with the distributor about how to remove the cement without damaging the board. They recommended denatured alcohol. This does not seem to work. I don't want to use heat either. Unless the cement is completely removed it's difficult to snap on the long replacement antennas. I want to route the long antennas away from internal noise on my larger aircraft. Any thoughts.
Feb 15, 2017, 02:24 PM
S.A.D. member
ivanc's Avatar
Carefully scrape the cement with a hobby knife.
Ivan
Feb 15, 2017, 03:35 PM
Closed Account
Feb 15, 2017, 04:36 PM
Thanks all. I'll se what I have. Maybe others will have a specific thing they use.
Feb 21, 2017, 08:36 AM
Xylene seems to be the best for removing the cement.
