Thread Tools |
This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies. |
New Product
DJI Mavic Pro Accessories ReleasedDJI Have quietly released the below accessories for the Mavic Pro, this included propeller guards and the long awaited Advanced charging hub, below is some more details
The Mavic Pro and accessories are available from DJI If you would like to support me you can choose to order from DJI via the below links The Mavic Pro http://click.dji.com/AOyVntGPqq4bW0r...m=link&as=0001 As with all my own blog post all links may be affiliate links and i will receive a small commission on any purchased through them , if you wish to support me and use these links then thank you however it is not expected. Mavic - Battery Charging Hub (Advanced) ![]() The Advanced Mavic Intelligent Flight Battery Charging Hub is designed for use with the Mavic Intelligent Flight Battery. When used with the Mavic Battery Charger it can charge up to four Intelligent Flight Batteries in sequence according to their power levels from high to low. Unlike the standard hub the advanced charging hub optimizes charging to improve efficiency and it is also Phantom 4 charger compatible so further reducing the charging times. Charge Time* with Four Batteries 4 hrs 10 mins with Mavic Charger Mains 3 hrs 15 mins using Mavic Car Charger 2 hrs 30 mins using Phantom 4 Charger / Car Charger These are really $55/£59 from the DJI Store. http://click.dji.com/APcD06x_You49sQEYcpX?pm=custom Mavic - Propeller Guard ![]() The Mavic Propeller Guard is specifically designed for the Mavic Pro, protecting people and objects from its spinning propellers, improving overall flight safety ![]() ![]() These are $15/£15 from the DJI Store Here http://click.dji.com/APt_O5f75wWkckGA5ERL?pm=custom Mavic - ND Filters Set (ND4/8/16) ![]() Specifically made for the Mavic Pro. This set includes ND4, ND8 and ND16 filters. ND filter reduces the amount of light coming into the sensor, giving you the freedom to create your own work by allowing more control of the camera's aperture, exposure time and sensor sensitivity settings. Put more simply, the ND filter helps avoid overexposed photos. The ND4 filter allows 1/4 of incoming light through, equal to a 2-stop filter. The ND8 filter allows 1/8 of incoming light through, equal to a 3-stop filter. The ND16 filter allows 1/16 of incoming light through, equal to a 4-stop filter. These are $35/£33 from the DJI Store here http://click.dji.com/AK7HbsfjkhXAajSYkVQv?pm=custom Mavic - Propeller Cage ![]() ![]() ![]() he Mavic Propeller Cage is used to protect people and objects from the Mavic's 7728 Quick-release Folding Propellers. The Propeller Cage improves overall flight safety. In the Box: Propeller Cage × 4 Securing Lock × 2 Pair of 7728 Quick-Release Folding Propellers × 3 These are $159/£163 from the DJI Store here http://click.dji.com/ADraQRMM7GZMhUp37yej?pm=custom Please note this page contains affiliate links, Should you wish to purchase these with out using these just navigate directly to the DJI website. |
