Revolectrix-themed power bank - RC Groups
Feb 09, 2017, 09:55 AM
Beckler's Avatar
Build Log
I didn't even intend it to be Revo color schemed but this is just a sealed lead-acid battery carrier I put together from stuff (including paint) I had around, so I thought I'd share here. Ended up being a perfect match for my DPL charger so I put a sticker on it. You might also notice the bump tag. It's a little 3d printed holder which makes bumping it quite easy - just snap it in and out of the base part.
Feb 09, 2017, 11:04 PM
Ohio AV8TOR's Avatar
Boy that's a great clean looking build Becker, well done.
Feb 11, 2017, 08:55 PM
Beckler's Avatar
Thanks Ohio, I'd do some things differently if I had to again. Like I might get rid of the relay which uses 2.5W. It is nice to have a power switch for the charger though. Also next time maybe li-ion. Lead acid is waaay too heavy... :|
Feb 18, 2017, 08:26 PM
Unregistered User
vimy g eaou's Avatar
Hello Beckler,
That is brilliant, mate.
So you designed it and printed it all out on a 3d printer?
It looks such a robust little unit too.
Feb 20, 2017, 08:38 AM
Beckler's Avatar
Originally Posted by vimy g eaou
Hello Beckler,
vimy: thanks... So yes just the bump tag holder I did on my printer. Was one of the first projects I did - one of the reasons it doesn't look that good (it does work tho). Used sketchup; it can't even draw a smooth circle - imagine that (you can see segments if you look closely). I soon uninstalled that junkware. The battery carrier is all made of wood.
Feb 21, 2017, 06:35 AM
Unregistered User
Hi Beckler, the metallic red cover you made, looks like it is printed or at least built up from acrylic sheet. I couldn't tell it is made of timber.
Doesn't the printer software come with templates or make it less sensitive?
Looking at this table:
https://i.materialise.com/blog/top-2...r-3d-printing/
You have the 2nd best software available, only topped by BLENDER.
Feb 23, 2017, 08:01 AM
Beckler's Avatar
Vimy, interesting link there. I think sketchup is popular because it's well-known (has been around a very long time, was originally by Google). It's just my experience it's not great for 3d printing (and read at least one other site say this). I use Fusion 360 now and it seems very good. I should try blender too.
