3DME - Vbar Neo Cage V2 - RC Groups
The CAGE V2 is a protective cage for the Vbar Neo that protects the unit under hard hitting conditions...
3DME has a nice little Cage for the V-Bar NEO to keep it safe during a crash.
The guys over at 3D Miniature Engineering have a few upgrades on their site for specific purposes, but they also have a couple that can be considered a necessity like the NEO Cage V2. It's designed specifically for the V-Bar NEO and is engineered to withstand a hard crash while protecting the NEO in the case. It also keeps you from having to fight with double sided tape if you have to swap the NEO to a different helicopter.
The CAGE V2 is made from billet aluminium and ABS plastic for the vertical supports that also act as servo plug retainers to keep it nice and neat. It also features precision CNC cutouts to perfectly snug the NEO into position. The V2 has refined standoff supports and optional glass blasted top and bottom plates.
For more information on the CAGE V2 click here.
  • Billet aluminium and ABS plastic.
  • Designed to protect the Neo in crashes.
  • The vertical supports act as servo plug retainers.
  • No double sided tape is required.
  • Easy to swap from heli to heli.
  • Even cracked and damaged cases can stil perform as expected when installed in the CAGE.
  • 66mm Long
  • 26.3mm Wide
  • 20mm High
  • Weight = 26 grams
Neo cage tutorial (2 min 13 sec)
