I've put a dozen cycles through my two silicone graphene standard voltage packs now. Very impressive. These are just 3s 2200 packs but IR matches are close averaging 5miliohms per cell at 62 degrees F.. Lower IR than any other 3s 2200 pack I've owned. Thanks Rocks, this more than makes up for the G6 dud pack with ridiculously high IR ( 40-50mOH) after just a few cycles and that was a 3S 5200 pack. My confidence in Hyperion has been restored
I say just go for a couple of short flights, 3~4 minutes or so, and try to land with a higher than normal voltage (50~70%) capacity, you can burst , just not for too long (10~15s), the whole point is to not make the packs too hot and straining/over-discharged during this phase. In my opinion, until about 3~5+ cycles out then you can the treat the battery how you want to. The most important thing is to store the battery at 3.7v, and don't over-discharge <3.2v. Here's some pointers on our website here: https://hyperion-world.com/en/blog/v...ymer-batteries |
Thanks for the info, here is an update: First I am not using these packs in my helis, I am using them for drag racing my 1/5 scale flux at 132'. Now that's with a 2028 800kv motor pushing a 25Lbs. car, I put 8 break in cycles on them first went to races this weekend and these packs were awesome to this point!!! They delivered the power I needed all day enough for over 10 passes at full bore, and they came home with almost 80% left in the tank!!! If these packs continue to produce like this I will never buy another brand!!! I will update more after the next racing day!!! jc |
These might be just what I need.... but
The G7 High voltage of 4.35 is a concern.( two reasons)
1. I am flying two 5s batteries ( in series) for 10s on my pattern plane. .15v ( extra per cell) x 10 means 1.5 volts more. Is this ok? 2. I just bought an ICHARGER 4010 duo. I can not figure out how to up the voltage( to 4.35 instead of the customary 4.2), or if it will even be capable of that? What do y'all think? |
WOW, I actually have a brain.... got it! Had to turn off TV... and concentrate...lol
So with that being said, I guess Hyperion HV is highly recommended? Or are they intended for a specific purpose? I wanted to get them for my 2M pattern ship, because I plan on flying it a great deal to become competitive .... Ideas? |
I guess I can ask Jeti if the Mezon ESC can handle the voltage....? IS that the only device that I need to consider? |
The only issues we've seen, only sometimes, is that the ESC will think that a 5S battery is a 6S battery, etc. So, if auto-detect voltage cut-off is enabled it might detect your battery incorrectly and the cut-off might happen prematurely. This is common on Castle controllers.
Was just trying to help Kasperwing.. If your motor runs hot on 10s with SV cells, it might run a little hotter with 10s Hv cells.. How much? don't know, probably not much. I disable auto detect cut off on my Castle controllers. If you plan to compete w/ your pattern ship, you might also want to check FAI rules on lipo cells.. For FAI F5B competition, only standard voltage lipo cells are allowed
Thats a good idea, I will be either intermediate or advanced come the new season. So yea, I need to find out if HV cells are allowed. Its only 1.5 volts more, and we fly at 1/2 throttle... so i can not imagine why HV would be disallowed.....hmmmm |
Yeah big difference in F5B where everything is always WOT and watt limiters are used. That extra punch from the Hv cells would up the watts significantly. For sport flying F5B, it'd be awesome though. I'm really hoping Hyperion will make some 5s 1800mah packs for us. We just do very short bursts at WOT pulling over 6,000 watts
