This thread is privately moderated by sundogz, who may elect to delete unwanted replies.
Feb 02, 2017, 01:05 PM
Platinum Card Member
sundogz's Avatar
Download
FJD 3D printable Jet Drives
Recent participation in the Home built jet drive boat 3D printed thread got me thinking how interesting it would be to design a jet drive that people could download the plans for to use for printing their own pump. And while I have plenty of ideas, I really lack the skills necessary to properly put it to .sdl for a printer, and since Justin won't have the time, I've enlisted professional SolidWorks user and engineer Unusual_RC to do that. So in thinking of what I would look for in a 'perfect' jet drive I came up with a wish list. We'll call them 'features':
1. Easy installation.
2. Scale-able, can be scaled for different sizes/applications
*Can not be scale-able due to off the shelf bearing sizes and differing impellers See post 72
3. Easy printing - no need for supports or special treatment
4. Off the shelf parts (bearings, shaft, etc)
5. Custom designed impeller
6. Strong design - not likely to be able to break anything
7. High efficiency - power to thrust ratio. To be determined by field testing
8. Integrated motor mount
9. Adaptable for means to reverse (reverse bucket, etc)
10. Option to use a thrust bearing (may be needed in the larger scales 40mm+)
11. Means for greasing the shaft without having to remove it from the drive.
12. Integrated steering servo mount (bolt-on)
13. Adaptability for use with gas engines ( just use 2 couplers and short piece of flex shaft)
Edit 7/28/17: Not bad. Those items in blue were incorporated into the design, while the one in red was not. Due to off the shelf bearing sizes, we will be scaling each drive and customizing bearing pocket sizes & motor mount screw spacing for each. No problem.
Here is an index to important pages if you don't want to read the whole thread:
Page__ Post ______________ Subject
6--------- 77 -----------------Suggested bearing, shaft, motor sizes, scale multiplier, etc.
10--------146----------------45mm V1 3D Jet Drive .stl files (obsolete) and impeller pin locations
11--------156 ---------------Build: trimming the freshly printed model
11--------161----------------Build - cont. Part 2
17--------245----------------Assembling the steering nozzle/stator housing/self bailing tube
17--------253----------------19mm (NQD) version 3D .stl files (discontinued)
19--------284----------------27mm (KMB) version 3D .stl files
22--------326----------------35mm V1 3D Jet Drive .stl files (obsolete)
24--------348----------------75mm V1 3D Jet Drive .stl files. (obsolete)
31--------465----------------65 mm V1 3D Jet Drive .stl files. (obsolete)
42--------619----------------55 mm V1 3D Jet Drive .stl files. (obsolete)
63--------939---------------45mm V2 3D Jet Drive files
63--------944---------------25mm V2 3D Jet Drive files
64--------948---------------65mm V2 3D Jet Drive files
64--------954---------------35mm V2 3D Jet Drive files
65--------964---------------75mm V2 3D Jet Drive files
65--------966---------------V2 Improved Steering Nozzle files
66--------986---------------55mm V2 3D Jet Drive files
70-------1036---------------15mm V2 3D Jet Drive files
73-------1089---------------Drive Dogs and Impellers
83-------1236---------------Sources for grease seals
87-------1292---------------Zero Backwash Nozzle and Reverse Bucket
88-------1318---------------Change in suggested filaments types
91-------1356---------------Check that seal tightness on the shaft!
91-------1357---------------In closing.....continuum !
Last edited by sundogz; Jul 07, 2021 at 10:10 AM. Reason: changed the name to FJD (free jet drive)
Feb 02, 2017, 07:11 PM
Agree with everything but #5.
Boat props are designed for a completely different purpose/running condition so they will not be efficient when used in a jet drive. Using a boat prop would also require the user to cut/grind/machine it to size and shape, which not everyone will be able to do. Careful design and quality 3D printing allows the production of purpose-built impellers specific to the drive, which will be more efficient, and have the bonus of being very cheap and easy to replace if something sneaks past the grate and chews up the impeller.
I'm completely staying out of the overall design of this drive because I'm curious to see what you guys come up with, but I will chime in if I feel there's anything helpful I can add outside of the design geometry. If my input isn't welcome, that's fine too.
Feb 02, 2017, 07:43 PM
Just Plane Nutts
AirDOGGe's Avatar
I'm sure everyone's input is welcome. Just nobody get upset if a suggestion is not accepted or applied. There are more ways than one to cook a hot dog...
Dammit. I just made myself hungry.....Be back later...................................
Latest blog entry: My You-Tube channel
Feb 02, 2017, 08:19 PM
helir22's Avatar
Sounds like a good plan... I like the idea of some sorta thrust washer between the brass tubing(if that is part of the design) and impeller like the kmb, or even better an actual thrust bearing somewhere in the jet body. Not just an extra radial bearing acting as a thrust bearing, that is either ignorant or dishonest and I am not reffering to any previous 3d printed design....
Feb 02, 2017, 09:12 PM
sundogz's Avatar
I agree a prop won't be as efficient, my thinking was that props were readily available, easy to adapt (turn it down with a stone and drill), and easy to fasten to the shaft with a drive dog. The printed impellers I've seen so far didn't give me a warm and fuzzy feeling as far as durability and fastening methods. We should try both, for sure.
Good idea. Since we're making this scalable, anything 40mm and larger will surely benefit from a thrust bearing absorbing the thrust instead of having the motor bearings take the brunt of the abuse. I'll add it to the 'wish list'.
All good stuff. Keep it coming.
Feb 02, 2017, 09:20 PM
helir22's Avatar
Also saves the coupler from an unwanted load.
Feb 02, 2017, 09:48 PM
The first impeller I got from Steve was printed; it looked as though it would break if you so much as looked at it funny. It did eventually break, but I think from some stringy algae getting sucked into the drive rather than just use. The ones Justin has sent me so far appear to be a lot more durable and should last longer. Significantly better print quality too.
Boat props also make toxic dust when you grind them as they are usually a copper/beryllium alloy which is bad for you if inhaled. Not so much of a problem if you are just balancing and sharpening by hand, but reshaping I would think about wearing a mask.
Feb 02, 2017, 09:49 PM
sundogz's Avatar
Where is that dad-gummed 'thumbs up' imogee when you need it?!
Feb 02, 2017, 09:56 PM
Fast electric boats maybe
Jeffro Bodine's Avatar
Keep it coming reading every thread
Feb 02, 2017, 10:17 PM
Just Plane Nutts
AirDOGGe's Avatar
Also brass, bronze, aluminum and stainless steel. One might also consider a PLASTIC prop, which would be far easier to mod for testing purposes before going to a metal one.
So true the toxicity of CuBe props. When I drilled out my Octura props to 4mm, I use a thick cutting oil like 30w motor oil to lube the drill. The bonus is the elimination of any chance of dust production.
My choice would be a CNC'd aluminum prop first. Durable enough, easier to mod than stainless or CuBe , and the light weight means less vibration and bearing wear at the very high rpms that impellers run at.
Feb 02, 2017, 10:30 PM
Shapeways will "print" things in a few different metals too. I've thought about trying this when the designs are finalized.
The CNC machined delrin impeller I got from Steve via Joe appears to be nearly indestructible.
Feb 02, 2017, 10:40 PM
helir22's Avatar
Also, I am not sure of the material they use but, the Thrasher and the Jettec use a water lubricated stator bushing with a hole at the end of the stator cone to facilitate flow. It's a nice low maintenance design.
Feb 02, 2017, 11:19 PM
sundogz's Avatar
My MB rigger project is on the shelf - something is locked up. I had replaced the stock bushings with stainless bearings in an effort to attain the highest speed possible. Mickie warned us bearings wouldn't hold up long, and is why it comes with bushings. I'll tear it down soon and see what happened.
Feb 03, 2017, 04:53 AM
sundogz's Avatar
Features
Why don't we call these things on our wish list 'features'. It just sounds better. I'll go back and change page 1 again (that page will no doubt be changed over and over as the project progresses). And keep in mind that at this stage in the game we are just adding the features that we'd like to see incorporated into/onto the drive. We'll go back and revisit those features to weigh their necessity and improve their design. Example-impeller/prop. A source was mentioned that can make a metal impeller from our designs, so even though 3d plastic printed impellers aren't suitable (yet), we won't need to consider using modified props with their inherent inefficiencies. I'll change that on page 1 too.
So on to more features:
Adaptability for use with gas (weedeater) engines. Self explanatory
Ability to grease shaft without removal from drive. ditto
Integrated steering servo mount. This is a holdover from the last project and is quite handy
Any others?
Feb 03, 2017, 12:56 PM
Just commenting more or less to subscribe. That said I think all the goals make sense. The only thing that sticks out is the idea of scaling. I like that idea but it could be tricky for it to literally be scalable. With shafts and bearings coming in specific sizes, if think it best to chose 4 or 5 common sizes. That way the bearings and shafts can be spec'd to each size.
I would like to see a range from 16 to 50mm. (Maybe 16 is too small but I would love to make a "pocket" jet boat")
I can't voice much to the performance related items but I can give advice on printing and materials if wanted.
Justin
