I just flew the Micro Vector on a Racing Drone - and I liked it!
The Eagle Tree Micro Vector is a killer racing flight controller, but it's also so much more...
Micro Vector Details
The Micro Vector is a miniature version of the Vector Flight Controller from Eagle Tree Systems. It is loaded with features and does nearly everything its full size counterpart can do. You can see the news article on the Micro Vector right here for more info. It comes with a case, but for the quad racers out there, you can remove the case and mount it like a traditional board right in the stack.
Tuning
This is one of the areas where the Micro Vector really shines. You can access the full menu system via the video feed and use your transmitter to change the settings. That means you can head to the field and get your quad tuned with one battery in a matter of minutes. Sure you could connect it to the software on your computer, change some settings, disconnect, fly, reconnect, change some settings, disconnect and fly, but doesn't that feel a bit outdated? Once you've tuned a quad with the Micro Vector you won't want to do it any other way. To access the menu, just flick the mode switch on your transmitter a few times and use the right stick to navigate and change your settings. Check out the video below from EagleTree for more info.
Flying the Micro Vector
The Micro Vector has a 32 bit processor, 8 kHz control loop and works with OneShot and Multishot ESC protocols. That means the board is every bit as capable as any other flight board available. I usually run the KISS FC and John from EagleTree wanted me to try the Micro Vector and see what I thought. He built, tuned and shipped a quad out to me so I could take it for a spin.
I have to say, I was impressed for sure. It felt great on the first flight and I had a blast ripping up and down the field on the first few flights getting a feel for it. Once I got comfortable with it, I went in for some close quarters flying around some trees in the park I was at and it handled every bit as good as my KISS quads. You can make adjustments to the rates, expo and PIDs to get it to feel and respond exactly how you want. It handled and felt every bit as good as my KISS setups with solid control. Here's a flight video of a few laps around the trees with the Micro Vector.
This quad will be shipping off to another tester soon, but after having played with it for a bit, I can say that I would be very happy with the Micro Vector had I purchased it. Sure the price is $99 which is more than most racing specific flight boards, but I feel that the value is there. Not only do you get a great flight controller, you also get a customizable OSD, Incredibly easy tuning via the goggles and transmitter as well as a robust stabilization and autopilot system with more features than you can shake a stick at. If you get tired of quads, you can switch the Micro Vector over to a plane and fly, shoot virtual air gates, take advantage of telemetry data, add-on sensors, autonomous flight, etc. The point is, the Micro Vector is every bit as good of a racing flight controller as anything else on the market, but it's also so much more than just a racing controller. It's certainly worth a look for your next build.
Check out the Eagle Tree Systems Micro Vector Here.
Old Feb 01, 2017, 05:05 PM
Nick_P is online now
Find More Posts by Nick_P
Dshot?
Old Feb 01, 2017, 05:25 PM
Jason Cole is offline
Find More Posts by Jason Cole
RCG Staff
Jason Cole's Avatar
From what I understand, no or at least not yet anyway.
Administrator
Old Feb 01, 2017, 06:30 PM
rcflyer729 is offline
Find More Posts by rcflyer729
SonicStrikeFPV
rcflyer729's Avatar
Originally Posted by Nick_P View Post
Dshot?
not yet
Old Feb 01, 2017, 11:41 PM
rpstar is offline
Find More Posts by rpstar
rpstar's Avatar
I'm going to be honest. Much of the OSD (including tuning via the sticks in the gui) can be achieved with a $6 minima osd board. Hence, it's not the OSD (albeit yeah a much more advanced one) that would get me to buy this. My question is how well does the air-gates mode really work on it? That seems to be the most compelling reason for it on a racing quad. I've only seen one video to date showing it and it looked ok but not much detail and too slow (ie: gates were nothing like racing gates).
Second, does this have an air-mode equivalent? Mostly interested in racing but air-mode freestyle is fun to play with.
Now, for fixed wing this is much more interesting but on the quad the above is what matters to me. Even if the air gates sucked for quads I might still consider it for wings as they would generally have a more open course.
Old Feb 02, 2017, 08:07 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
You need the separate GPS module for that though, and space is normally at a premium!
It looks nice enough but for quads an F3/F4 board plus BF/CF plus micro minimOSD is a tough combo to beat.
I agree it looks great for fixed-wing though.
Old Feb 02, 2017, 11:01 AM
SonicStrikeFPV
rcflyer729's Avatar
It does have something very similar to air mode that works just as well if not better.
Old Feb 03, 2017, 08:57 AM
schpanky is online now
Find More Posts by schpanky
(ҿӬ)
what's the adoptation like coming from a mwii/base/clean/beta/race-flight controller?
IE: what are some things that your average FPV-noob (such as myself) going to experience that may not be explained well or is environmentally-different?
Old Feb 18, 2017, 09:41 AM
Ari33 is online now
Find More Posts by Ari33
If the price was closer to current F3 & F4 boards I'd try it, but until then it can't compete no matter how good it might be..
Old Feb 18, 2017, 11:09 PM
rpstar is offline
rpstar's Avatar
For a racing quad that seems to be pretty much the general consensus. I'd like one for a wing though.
Discussion New to racing just FPV drone racing and would like to ask some questions DeadPool859 FPV Racing 1 Nov 19, 2016 01:39 AM
Discussion Racing quad kits and rtf quads 10% off for rcgroups members kits just $120 ermagherd Vendor Talk 0 Oct 03, 2016 08:44 AM
Discussion mount for FPV camera driven by "head-tracker-like" tech on racing quad??? Steve_in_NJ FPV Equipment 7 Mar 23, 2015 07:59 PM
Found *Wanted* ESC with Reverse (Like the ones used on 3D quads) Just need one. vacahtu Aircraft - Electric - Multirotor (FS/W) 6 Jan 09, 2014 10:26 AM
Alert First flight with 3.14 NAZA firmware and my quad flew perfect just like 3.12 blade strike Multirotor Electronics 27 Jul 10, 2013 01:14 AM
