Jan 29, 2017, 11:11 AM
Addicted FPV Pilot
NikkyFPV's Avatar
The Best AIO FPV Combo - BoldClash F-03
Hello Guys I have the opportunity to unbox/review the BoldClash F-03 AIO FPV Combo. I think it's the best on the market.
Link for it : http://www.tmart.com/sl/58577e37d1291
Here is the Unboxing/Review video :
Vendor's Description :
Miniature and lightweight, the Boldclash F-03 AIO 5.8GHz 40CH 25mW/200mW Cam VTX Support 3V-26V NTSC/PAL with Clover Antenna is a 2-in-1 VTX camera combo tailored for FPV applications. High-grade image sensor captures crisp, clear flight footages with stunning details. Wide angle lens covers a broader view. LED indicators display channel and frequency group information. And it supports NTSC/PAL switch and vertical inverted image switch. So, what are you waiting for? Click and get it right now!
FEATURES
Miniature and lightweight, tailored for FPV applications
5 bands, 40 channels with race band
NTSC/PAL switch
Support 25mW/200mW selection with digital tube dot display
Vertical inverted image switch and horizontal mirror image switch
Support TX RF output power enable/disable
Support mic output enable/disable
Miniature digital tube display alternately channel and status information
Omnidirectional clover antenna
Support OSD with external video in/out
Specifications
Brand Boldclash
Model F-03
Frequency Band 5645-5945MHz
Channel Customer 40
Modulation Type FM
Channel SEL. Touch Switch / PWM
Channel Indication +1 2S ABCDE (Channel Group and Channel Alternated Display, Touch Button Channel+1 and Frequency Group A/B/C/D/E+1 Switch Needs Touch Buttons Until 2S)
Transmit Power 131dBm & 231dBm
Frequency Control PLL
All Harmonic Max -50dBm
Frequency Stability 100KHz (Typ.)
Frequency Precision 200KHz (Typ.)
Channel Carrier Error 1dB
Antenna Port 50
Input Format NTSC / PAL
Sensor PAL: 960 x 576 @1/3
Effective Pixel 976*592
MAX. Frame Rate NTSC: 60 fied/sec PAL: 50 fied/sec
Lens Angel H110/V68
Base-band Interface 5pin Header +P2.54*3+ P2.54*3
Power Consumption Max [email protected] DCIN
Supply Voltage 3V-26V
Operating Temperature -10C - +60C
Ambient Temperature 25C
Dimensions (0.91 x 0.79 x 0.39)" / (2.3 x 2 x 1)cm (L x W x H)
Weight 0.34oz / 9.7g
Package Includes
1 x Boldclash F-03 AIO FPV CAM VTX
2 x Clover Antennas
PROS
- A lot of functions
- The Suppy Voltage have very big choice, from 1 to 6S battery
- 25/200mW Switchable
- Led on the back which shows you on what channel you are
- They give you spare antenna, so if you break the one which is on the Combo, you can solder the spare
- Pretty Decent Range
- Very Clear Image on the Screen
CONS
- A bit Heavy
- Can't be used on H36, E010, F36 quads because of the weight ( they can't handle it )
Some pictures :
So, that was for my review. Stay tuned, soon i will upload DVR Footage from this camera If you like what i am doing, please subscribe for my channel. I will be so happy if you do this
