OpenTx 2.2 - RC Groups
Jan 28, 2017, 05:08 PM
RCdiy
RcRav's Avatar
OpenTx 2.2
(Updated to keep current as needed. You may request updates by posting in the thread.)
OpenTX 2.2.0 (2017-05-30)
http://www.open-tx.org/downloads
Donate To The Project
http://www.open-tx.org/donations
OpenTX 2.2 Manual
By RCdiy
http://rcdiy.ca/opentx-guide/
By the developers and community contributions
https://opentx.gitbooks.io/manual-fo...x-2-2/content/
Quick Start Guide
A Taranis Q X7 has been used but similar steps apply to other transmitters.
http://rcdiy.ca/downloading-installi...ounds-wizards/
- Installing the microSD Card
- SD Card Warning
Description:
- Connecting the Tx & Computer
- Downloading, installing & Configuring Companion
- Backing Up The Tx
- Downloading & Writing OpenTX To The Tx
- Downloading & Copying The SD Card Contents To The Txs microSD Card
- Safely Disconnecting The Tx & Computer
- Donating To The OpenTX Project
Taranis Q X7 Quick Start - Downloading & Installing Companion OpenTX 2 2 & SD Card (Audio, Sound) (12 min 22 sec)
Changes Between 2.1.9 and 2.2
http://www.open-tx.org/2017/05/30/opentx-2.2.0
OpenTx 2 2 (4 min 26 sec)
OpenTX 2.2 Sound Packs & SD Card Warning
http://rcdiy.ca/opentx-sounds-announcements/
https://opentx.gitbooks.io/manual-fo...ced/audio.html
Official sound packs are obtained from Companion > File > Download SD Contents
There is now a version file that is checked to help determine that the firmware and sound pack match. No more wrong units due to mismatched firmware and sound files. Checks for the existence and content of opentx.sdcard.version in the root os the SD Card. You can still use your own files but make sure you have this file.
Description:
Sound File Differences Between 2.1 & 2.2
SoundsDifference.xlsx.zip SoundsDifference.xlsx
SoundsDifference.xlsx.pdf SoundsDifference.xlsx
If you unzip and open the Excel file you can sort the differences.
Click on the down arrow of the column header you want to sort by.
Additional sound packs posted.
https://github.com/RCdiy/OpenTxSound...0Sound%20Packs Generated using Mac voices.
http://open-txu.org/v2-2-resources-2/ Amber - Human voice
https://github.com/pinkywafer/OpenTX...anne/releases/ Joanne - Human Voice
Calibrate OpenTX
Taranis Q X7 OpenTX Tutorial - Calibration (2 min 16 sec)
Jan 28, 2017, 06:17 PM
Release candidate 10 is out
http://www.open-tx.org/2017/01/27/opentx-2.2.0RC10
Jan 30, 2017, 09:57 AM
RCdiy
RcRav's Avatar
Originally Posted by Jim Taylor
Thanks, updated post accordingly.
Jan 30, 2017, 12:37 PM
I posted this in the Horus Opentx thread but this may be a better place to ask, if not let me know and I will delete it.
Have pitot speed sensor installed. I would prefer that the telemetry call out just speed numbers but not add "miles per hour" to every repeat. So 56,59,60 not 56 miles per hour, 59 miles per hour, exc. Wouldn't care of it ever used the wave file. Is there a way to do this? Thanks
Jan 30, 2017, 12:45 PM
S.A.D. member
ivanc's Avatar
Replace the "mph0.wav" and "mph1.wav" files with empty ones or with files with 0.5 second of silence?
Ivan
Jan 30, 2017, 12:49 PM
Thanks, didn't know if it would really be that easy. Sweet.
Jan 30, 2017, 12:56 PM
S.A.D. member
ivanc's Avatar
It's just a guess on my end - I've played with replacing sound files around but never used empty ones so I am not sure how OTX will react on those. That is why I suggested 0.5 seconds of silence. You may even try with less than that - the idea is for OTX to be able to correctly process the file rather than looking for a missing file (file renamed or deleted) or a file with no information in it (an empty file).
Ivan
Jan 30, 2017, 07:32 PM
Ivanc, worked like a champ. Created a very short wave file and replaced mph1 file. Much better.
Jan 30, 2017, 07:44 PM
S.A.D. member
ivanc's Avatar
If you left mph0.wav intact it may read out loud "One mile per hour" if your telemetry happens to return that value.
Ivan
Jan 31, 2017, 07:13 PM
RCdiy
RcRav's Avatar
Anyone come across a list of enhancements/changes/new for OpenTx 2.2?
Other than this reference taken from the release candidate posts on the opentx website.
"A rough view of the changes in OpenTX 2.2 can be found here."
Feb 01, 2017, 04:25 AM
mikeshellim's Avatar
Not intended to be an exhaustive list of changes, but I've written up my experiences converting a setup from 2.1 to 2.2:
Preparing your setups for OpenTx 2.2
Feb 02, 2017, 03:20 PM
RCdiy
RcRav's Avatar
Thanks!
I downloaded RC10 Companion for MAC.
I noticed that GVAR names are still 6 characters. (Taranis + profile if that makes any difference).
Feb 02, 2017, 07:29 PM
Thanks!
Hmmm.... for the Horus it seems to be just 3 characters. There are inconsistencies in N362 for example Companion with Horus setting has 8 character limit for mixer names, the tx firmware only allows 6. I've raised an issue for this on Github.
Feb 03, 2017, 02:35 AM
RCdiy
RcRav's Avatar
You were correct. On saving and reopening they were truncated to 3.
I have list of differences which I'm working on with help from the developers. It will be shared soon. I went through issues on GitHub and compared Companion 2.19 with 2.2 RC10.
Were you able to get jpg and png image files to work? Is it only Horus maybe?
Feb 03, 2017, 09:26 AM
Any change a corrupt model file could cause the Horus to lock out a receiver and not reconnect even though the receiver is powered up. I posted in the Horus Opentx thread but I'm looking for any help I can get. Running N362 and updated SD card files.
Discussion Issue Telemetry Battery Taranis OpenTX 2.1.9/Naze32/D4R-II/Cleanflight1.2.4 prophet_id Scratchbuilt Multirotor Drones 1 Feb 22, 2017 12:31 PM
Discussion Telemetry Battery Taranis OpenTX 2.1.9 / Naze32afroRev5 / D4R-II /Cleanflight1.2.4 prophet_id Multirotor Drone Talk 1 Dec 01, 2016 08:30 PM
Discussion FrSky Taranis with OpenTX 2.0 (Take 2) TrueBuld Radios 2 Sep 22, 2016 03:18 PM
Help! Turngy 9XR Pro opentx 2.0.8 to 2.1.7 upgrade failed robinzeng Radios 0 Jan 14, 2016 07:58 AM
