DYS BE1102 10k and 7800KV 100mm Quad Motors
Available through ReadyMadeRC, the DYS BE1102 is a small brushless outrunner capable of some extreme RPM's.
Tiny Power!
Jump on the tiny quad bandwagon with these miniature mouse motors from DYS! Available through RMRC, the DYS BE1102 is only 14mm x 9.5mm and weighs in at a hefty 3.5 grams. Its available in 10,000kv and 7800kv, and both retail for $10.99 each. CLICK HERE for more info on the DYS BE1102 motors.
One option for a suitable frame is the SPCNC - Surface 120 FPV Racer Frame Kit 2.
DYS BE1102 Specs:
Specifications: KV: 10000
  • Stator Diameter: 11mm
  • Stator Length: 2mm
  • Shaft Diameter: 1.5mm
  • Motor Dimensions(Dia.*Len):149.5mm
  • Weight (g):3.51g
  • No.of Cells(Lipo): 2-3S
  • Max Continuous current(A):7.7A
  • Max Continuous Power(W):85.5W
  • Internal resistance:0.35Ω
Jan 31, 2017, 07:55 AM
I void warranties
What would be approximately the maximum capacity of a 3s pack a model built with these could carry? I realize they're for super tiny build which I have no exp with but I'm looking at building either a halo 90 or a Owl mini (88mm) and trying to figure out if I could run these of should go with something like an 1105 or even 13xx instead
Jan 31, 2017, 10:50 AM
I just wanna fly, fly, fly
Brainstorm's Avatar
CK: You might want to search threads for the Halo and Owl for motor recommendations. The 1102 are best suited for extremely light builds. IMO, this would disqualify any frame with heavy enclosed props, e.g. the two you mention. Only exception would be the RS-90, for which RotorX designed the original RX1102 7800KV motors.
Feb 07, 2017, 10:52 PM
Can you get tiny escs to go with these?
Feb 10, 2017, 02:00 AM
seams good
Feb 17, 2017, 09:06 AM
cyberbillp's Avatar
85 watts? Is that for real? At 2S that's 10 amps.
Feb 28, 2017, 06:54 AM
100mm quad motors are massive!
100 mm = 10 cm = 3.93701 inches
