AXI 5345 HD Sailplane Outrunner Brushless Motors
If you have a large electric sailplane project, you don't use cheap questionable quality components to put it together. No, you want the best stuff that will last...
New High End Sailplane Motors from AXI
If you have a large electric sailplane project, you don't use cheap questionable quality components to put it together. No, you want the best stuff that will last. On the power system side, you now have more options as Model Motors has some new heavy duty high quality 5345 motors. They feature top of the line build quality and efficiency, a long shaft for nose mounting and two different windings to choose from. These are some of the highest quality motors you can get, so don't skimp out when it comes to your power plant.
Check out the AXI 5345 HD V2 Sailplane Motors at Esprit Model.
