Jan 25, 2017, 12:04 PM
New Product
Flyduino KISS CompactCTRL "CC" (aka AIOv2)
The follower of the AIOv1 is here! Meet the KISS CompactCTRL
Get yours here: http://flyduino.net/KISS-CompactCTRL-CC-All-in-One_1
Specs of the CC
  • Weight of PCB: 11g (without wires)
  • Size 35x42mm (with cut off corners)
  • Mounting holes 30x30mm, 3.2mm diameter
  • 4x KISS ESC 32bit ESC's 2-4S 16A (21A active current limiter)
  • KISS FC F3 32bit with serial, buzzer and LED ports
The CC supports full telemetry and logging via serial port. Setup is the same as with the regular KISS FC.
More Informations: http://kiss.flyduino.net/kiss-compac...linone-fcescs/
movr5r1 t2 2600kv 5x4x4 v1s hqprop kiss cc 4s1300 75c (2 min 35 sec)
CCConnection plan by Philipp Seidel:
More useful KISS documentation and manuals:
http://blog.seidel-philipp.de/catego.../flyduinokiss/
Do you like the contributions by Alex aka FedorComander?
We at Flyduino do! Alex chose to setup a PayPal donation button. So if you appreciate his efforts please donate here:
https://www.paypal.me/FedorCommander
Jan 25, 2017, 12:15 PM
Team WarpSquad
Brainstorm's Avatar
Nice! That was quick! KISS CC, the AIO formerly known as v2.
Can we assume the 16A rating with 21A cutoff will operate somewhere between the original KISS 12A ESC and 18A ESC? Will it support a buzzer and LED now? I like the new corners, even though they don't look as fancy as rounded ones on AIO v1.
I bet this higher-amp version of the KISS AIO/CC will sell like hotcakes, or warme Semmeln, as the case may be.
Jan 25, 2017, 12:25 PM
ronnw's Avatar
Congrats on the release. This lineup of Kiss AIOs is going to be the game changer everyone has been waiting for ;-) Nice work to everyone involved :-)
Sent from my LGLS740 using Tapatalk
Jan 25, 2017, 12:31 PM
Team WarpSquad
Brainstorm's Avatar
PS: Any chance for another batch of lower-amp AIOv1 at a reduced price? Or is the CC/AIOv2 the only game in town now?
Jan 25, 2017, 12:38 PM
The AIOv1 is dead. Long live the CC!
Jan 25, 2017, 12:45 PM
THALLfpv
Argh..... Order placed...... Any hope for iBus support?
Jan 25, 2017, 12:53 PM
Team WarpSquad
Brainstorm's Avatar
OK. Thanks. That settles the question.
Maybe Philipp should close the old thread then?
Last edited by Brainstorm; Jan 25, 2017 at 01:37 PM. Reason: Misspelled Philipp's name.
Jan 25, 2017, 12:59 PM
Great news, anyway, is in plan a CC for more amps ?
I'm not sure with 16/21A what motor/props are safe for a 5 inch setup
Jan 25, 2017, 01:02 PM
DQUAD OBSESSION-KRAKEN 5X
Lasercopter's Avatar
Ordered mine!!
Jan 25, 2017, 01:14 PM
Team WarpSquad
Brainstorm's Avatar
Mario: I think the video posted above speaks for itself. Read the description on Youtube for details.
Jan 25, 2017, 01:52 PM
"German jerk"
DIE_KUH's Avatar
According to the manual: Yes, both.
Damn, I can't justify to order one right now.
Jan 25, 2017, 01:53 PM
https://www.youtube.com/watch?v=dteIciTYaLU
yes its a save rating / layout so you can run it to the 21A limit without risk. if it gets enough cooling it will do the 21a as long as you need it. and if it gets too hot, it will go into overtemperature protection so it reduces the output power eaven more. we choosed the 21A limit to make sure it dont comes close to its HW limits.
but using much too big motors is kind of sensless then because they wont give you more power as the ESC's will limit them.
regards
Felix
Jan 25, 2017, 01:56 PM
sz4dy's Avatar
what about rs2205s 2300kv spinning dalprops tri 5045 v2 on ~280g fpv setup? Is it going to work ? I've never seen more than ~73Amps at OSD...
Jan 25, 2017, 02:02 PM
it should. but in fast movements it might get a bit reduced as you might never have more then 73A overall but maybe sometimes more then 21A on one motor.
regards
Felix
Jan 25, 2017, 02:07 PM
"German jerk"
DIE_KUH's Avatar
Sure, why not. Any combination where you don't exceed 84 A is fine. Above that, you're waisting a bit of potential, but it'll still work.
Only thing you shouldn't do is use the CC with a motor/prop combination that can't endure the 4x21 A.
