HPI Savage XL Flux 6s - RC Groups
HPI adds to the Savage lineage with the all new XL Flux! This beast sees a number of upgrades and improvements over past Savages. Let's take a look!
Power and Stability in the Savage Monster Truck Package
We all know the Savage monster truck from HPI; it's lineage starts back in 2002 with the Savage 21. Fast forward through sixteen different variations, and we have the monstrous 1/8th scale Savage XL Flux! This new Savage comes with a Flux Torq 2200kv brushless motor and an ELH-6s ESC with 150A maximum continuous amp draw! Also in the list of features is an all-metal transmission and gears, big-bore nylon shocks, heavy duty dogbones and outdrives, a relatively low center of gravity, and a TF-40 2.4GHz transmitter.
The Savage XL Flux retails for $729.99 and is currently in pre-order.
CLICK HERE for more on the Savage XL Flux, available through Tower Hobbies
Savage XL Flux Features:
  • 2.5mm thick rigid 6061-series aluminum TVP (twin vertical plate) chassis
  • Extra low CG for cornering control and ability
  • Wheelie bar
  • Twin battery boxes for a variety of battery types
  • Four wheel shaft drive
  • HPI Flux Tork 2200Kv brushless motor with machined cooling fins
  • 7075 billet aluminum motor mount
  • Waterproof Flux 6S ESC with proportional brake
  • Big Bore nylon bodied, oil-filled shocks
  • Adjustable front and rear caster and camber
  • All metal gear transmission with rubber-sealed ball bearings
  • Equipped with machined, super heavy duty bevel gears on the differential
  • Machined steel, 44 tooth spur gear
  • Suspension uprights designed for big tires and high weight
  • HPI Warlock tires with chrome finish 3.3 diameter
  • GT-2 on/off-road tires with blocky tread pattern and heavy-duty sidewall teeth
  • Trimmed and painted GT-2 body
Jan 25, 2017, 02:54 PM
Team D performance design
dogoman's Avatar
Is .5mm aluminum even a thing?
Jan 25, 2017, 02:55 PM
RCGroups Editor
Matt Gunn's Avatar
LOL. I copied it from a specs sheet. Fixed!
Jan 25, 2017, 02:56 PM
dogoman's Avatar
This thing looks like a real beast! I bet it would make an awesome basher
Jan 26, 2017, 11:21 PM
Same truck over and over wow looks just like my x wife's that I bought her around 2006 but gas
Mar 05, 2017, 02:27 AM
Anthology5251's Avatar
wait a minute, I thought they have issues with this chassis, it was easily bent/warp in a crash test
