Video
Original HSP® 94680T2 1/18 2.4Ghz 4WD Electric RTR Rock Crawler
HSP® 94680T2 Technological Features
--2.4Ghz 2CH remote controller --4WD drive system --RC260 brushed motor --Full ball bearings throughout the whole vehicle --Multi-link suspension allows for smooth crawling --Four wheel driving provides tremendous grip for wheels --Twin vertical plate(TVP) are firmly locked to protect battery plate --Alloy lower suspension link bars with captured ends --3-Gear center-mounted transmission --Solid axle mount provides protection for front/rear shaft --ESC w/reverse function --2-channel receiver HSP® 94680T2 Unboxing Video
HSP® 94680T2 Test run Video
Original video from our Sponsorship Youtuber Songo from SongoLand HSP® 94680T2 Specifications: Brand name: HSP Item name: RC Rock Crawler Transmitter: 2.4Ghz 2CH Battery charger: EU/US/UK plug optional Wheelbase: 220mm Ground clearance: 30mm Wheel diameter: 95mm Wheel width: 34mm Motor: RC 260 ESC: Brushed 60A Gear ratio: 1:88 Servo: 2.5kg Drive system: 4 wheel drive Material: Metal Battery: 7.2V 1100mAh Ni-MH battery (XT60 Plug) Transmitter power supply: 4 * 1.5V AA batteries (Not included) Size: 310 * 170 * 180mm Item weight: 915g HSP® 94680T2 Package List 1 * HSP 1/18 94680T2 RC Car 1 * 2.4Ghz 2CH Transmitter 1 * 7.2V 1100mAh Ni-MH Battery (XT60 Plug) 1 * Battery Charger 1 * Instruction Manual Coupon code: HSP946 Coupon discount: $40 OFF Expired date: 21st Mar. 2017 Check more: HSP 94680T2 RC Rock Crawler |
Reason: add coupon
Dimensions of the wheels please? Which hexagones are used?
