This thread is privately moderated by davidmc36, who may elect to delete unwanted replies.
Jan 20, 2017, 03:51 PM
No bounce, No play.
davidmc36's Avatar
Build Log
DX18 install of RC Technik Tip Switch Sticks
This blog entry will detail the install of Tip Switch Stick from RC Technik into a DX18 Stealth.
https://rctechnik.de/stick-switch-Spektrum/10001.html
First entry is of the spare gimbals I acquired. Local member freechip was good enough to hook me up with the donor items. Also in the picture are the sticks that came in the mail today.
Jan 20, 2017, 04:01 PM
No bounce, No play.
davidmc36's Avatar
Pulling the stems
Getting the stock stems out is a breeze. First there is a small ridge around the stem base. Put a washer on that is big enough to protect it. Thicker than the ridge height, hole bigger than diameter, just a tiny bit.
Jan 20, 2017, 04:04 PM
No bounce, No play.
davidmc36's Avatar
Take up the space
Stack some more washers with the last one the hole a bit smaller, just big enough to clear the threads. Remove the set screw from the stick end and thread it on the stem, upside-down.
Jan 20, 2017, 04:09 PM
No bounce, No play.
davidmc36's Avatar
Pulls off with finger pressure
All I had to do was turn the stick end with my fingers. There is a bit of pressure for about 1/6 of a turn and then it comes out with just a tug.
Jan 20, 2017, 04:13 PM
No bounce, No play.
davidmc36's Avatar
Wire Path
On the bottom side you can just see the edge of the hole. Gimbal will have to be disassembled to find proper routing for the wires.
It will be the best way to press in the new stems anyway.
Jan 20, 2017, 04:16 PM
No bounce, No play.
davidmc36's Avatar
Small difference
The new stem is just slightly larger than the stock. The instructions mention some drill bit sizes but I will also get the dial calipers into the game to confirm what to drill them at. Should only be a few thousandths.
Jan 20, 2017, 11:50 PM
No bounce, No play.
davidmc36's Avatar
Remove glue from wire
Remove the glue holding the wire in place. It's a bit stretchy so grip it with small needle nose and pluck off until wire is free.
Jan 20, 2017, 11:54 PM
No bounce, No play.
davidmc36's Avatar
Remove gimbal
Remove four screws holding inner gimbal bearing caps.
Jan 20, 2017, 11:57 PM
No bounce, No play.
davidmc36's Avatar
Wire Path revealed
With the center of the gimbal removed you can see there is a nice opening for the wires to pass through. Gave it a quick test run.
Jan 21, 2017, 09:35 AM
No bounce, No play.
davidmc36's Avatar
Remove Stem
Remove the stem from the new stick.
Get the gimbal piece set up in the drill press. All drilling will be turning by hand. Just using the press to square up the entry. I actually took the belt off so the spindle can be turned easily by hand without turning drill press motor.
Jan 21, 2017, 09:41 AM
No bounce, No play.
davidmc36's Avatar
Finish Drilling
If you see the drill peek out the hole you know it is deep enough.
Jan 21, 2017, 09:49 AM
No bounce, No play.
davidmc36's Avatar
Final Size/Press In
You can see there was not a lot of meat removed by the size of the raised ring, before and after.
Once you have the hole to the right size, I ended up with #27 drill as final size, set up to press the stem in.
An arbor press would come in handy but if you don't have one a vise works fine. It's a bit tricky getting started straight but with the right size hole you can get it just started by hand so it does not fall on the floor then push it in with the vise.
Jan 21, 2017, 09:59 AM
No bounce, No play.
davidmc36's Avatar
Route and Assemble
Since the stick will not fit through the opening in the gimbal you have to start putting the wires through, then re-assemble the bearing caps.
The instructions show the option of routing the wires on both sides of the pivot point. Depends on what you want I guess. If you choose to split them up be very careful not to cross them over as they go through the stem and out the hole. I went with all on one side and will need to get all the routing safe when installing gimbal into radio.
New Gimbal in the Spotlight ready to be installed.
Those details will come over the next little while.
Jan 21, 2017, 10:19 AM
AndyKunz's Avatar
What switches are these going to replace on the tx body??
Andy
Jan 21, 2017, 10:47 AM
czorzella's Avatar
Doesn't these cables interfere with the smoothness of gimbal movements?
Carlos
