FMS Futura PNP 80mm EDF
The Futura from FMS is an affordable EPO 80mm EDF that requires a 6S 4000mAh LiPo. It comes with retracts, servos, and EDF/motor/ESC already installed.
An Affordable High-Performance EDF
We first heard of the new FMS Futura Jet back in early December. Now, the 80mm EDF is gearing up for it's official release in early February! This 41" wingspan Futura sports a 3270-2000kv motor and an 80mm 12-blade fan unit. It comes with a 100A Predator esc, retracts with gear doors, andis designed around a 6s 4000mAh or similarly sized LiPo. The FMS Futura PNP 80mm EDF retails for $329.99 and will be available at Horizon Hobby and other FMS retailers.
Features:
  • Powerful 3270-KV2000 motor
  • 80mm 12-blade Fan unit
  • High quality Predator 100A ESC
  • EPO40 foam material
  • Digital metal gear servos throughout for better controlling capabilities
  • New CNC-processed shock-absorbed metal landing gear set (Worm diameter, 10mm) helps to withstand those less-than-perfect landings.
  • Multi connector for one-step installation (With the latest multi-connect technology, FMS has streamlined the wiring system, eliminating wiring problems and making installation easier)
  • Oversized battery compartment
  • Button-type canopy hatch
  • No glue required, screw-together construction
  • Environmentally friendly water-based paint for better color and gloss
CLICK HERE for more info on the FMS Futura PNP 80mm EDF
CLICK HERE for the RCGroups thread already in progress
Jan 19, 2017, 11:26 AM
Can you edit the intro to correct the cell count, you have 4s.
Fancy one of these when the fleet thins.
Jan 19, 2017, 12:03 PM
RCGroups Editor
Matt Gunn's Avatar
Thanks! Long morning already...
