FuriBee Fuuton200-FPV Racing Drone-AIO F3 FC+OSD+PDB - Page 47 - RC Groups
Sep 11, 2017, 02:15 PM
Get It? - Got It!
Maverickk's Avatar
Capt and Solo, Thank you for your suggestions and help. I will give this a try this weekend and report back.
Sep 12, 2017, 02:13 AM
aka RCFlyer85
Irock1985's Avatar
Originally Posted by Maverickk
Irock - thanks, but I followed the instructions and loaded the 3.1.1 configurator and launched, saved, saved and rebooted, tried changing configurations w/save and reboot. Still same problem- nothing showing on receiver tab.
Any other ideas?
thanks
Most likely you'll need to reflash and start from scratch
Sep 12, 2017, 04:11 AM
Fan of just about anything RC
SoloProFan's Avatar
I have a cli dump with stock 3.17 settings for the Fuuton, if needed
Sep 12, 2017, 04:38 AM
aka RCFlyer85
Irock1985's Avatar
Or that...
Sep 13, 2017, 02:27 AM
New Furibee QAV220.. Those motors look familiar, here's hoping!
https://www.gearbest.com/brushless-f...pp_791917.html
Sep 13, 2017, 09:51 AM
Those motors are way too tall compared to the old ones...
Sep 13, 2017, 05:23 PM
SuperFuuton "V2"
Introducing the SuperFuuton "V2" ..... shaved off 25g's...
Sep 13, 2017, 06:56 PM
Update: just tried out the vtx signal using a test I do for all my quads and surprisingly it performed the best! Everything fitted unbelievably perfect with absolutely no room to spare anywhere... I'm very happy ...
Sep 13, 2017, 07:21 PM
What is the bootloader button meant to be used for that's next to the usb port?
I was messing around and tried connecting up the quad while holding in the button, BF does not start in DFU mode if that's what it's meant to be for?.
So is it for flashing new FW? since it's already got BF on it from stock, to update will i need to use that button or just flash with the quad connected normally?.
Sep 13, 2017, 10:16 PM
This explains the flashing process pretty well. The bootloader buttons are really only needed if flashing fails for some reason.
Betaflight 3.2 Ultimate Setup Guide (24 min 18 sec)
Sep 14, 2017, 04:03 AM
Thanks man, pretty noob question but I noticed my BF didn't switch to DFU mode so wondered if I had done something wrong.
Thanks!
Sep 14, 2017, 09:52 AM
Thanks!
mine doesnt swith to DFU mode even pressing the button or at least i'm not able to make betaflight to connect it
Sep 14, 2017, 02:52 PM
Have you tried the driver fix tool?
Sep 14, 2017, 03:19 PM
Hey it works... download "Demonstrator GUI" ... connect drone to it and try to open it.... now it won't open here either.... so unplug and now plug it into betaflight using the boot button.... Hey it works! ... I've done this on 3 different flight controller boards now.....
Sep 15, 2017, 11:09 AM
I'm getting a significant amount of noise (lines going across screen) in my video feed. Has anyone tried installing some sort of filter?
