Jan 18, 2017, 03:10 AM
youtube.com searchfor danqfpv
Danq0's Avatar
Mini-Review
FuriBee Fuuton200-FPV Racing Drone-AIO F3 FC+OSD+PDB
FuriBee Fuuton 200 - 200mm FPV Racing Drone <<<click<<
5.8G 600TVL CCD / F3 Flight Controller with OSD PDB / BLHeli - S 20A DShot150 ESC
Discontinued
using code RC18OFF takes off 18%
►Fuuton BNF: http://www.gearbest.com/brush-fpv-ra...?lkid=10330686
►Fuuton PNP: http://www.gearbest.com/brush-fpv-ra...?lkid=10322914
Replacement Parts:
▼Frame: http://www.gearbest.com/racing-frame...?lkid=10582227
▼Flight Controller: http://www.gearbest.com/multi-rotor-...&lkid=10183821
▼Motor: http://www.gearbest.com/motor/pp_617...?lkid=10582225
▼ESC: http://www.gearbest.com/esc/pp_61726...?lkid=10582224
▼5040 Propeller: http://www.gearbest.com/propeller/pp...?lkid=10582223
▼Antenna: http://www.gearbest.com/fpv-system/p...?lkid=10582229
▼LED Board: http://www.gearbest.com/multi-rotor-...?lkid=10582222
Contents
Post1
Specifications
Videos
Pictures
Review
Pros & Cons
Final Thoughts
Post2
Weights
DIY-Modifications-Tuning
Main Features
- 3K full carbon fiber, true "X" configuration, 200mm wheelbase, 4mm thick chassis
- Holybro Kakute AIO V1.0 F3 Flight controller w/integration OSD and PDB <<< Excellent board!
- 1/3 Super HAD II CCD, PAL, 600TVL camera, 2.5mm lens, 140-degree FOV
- 5.8G 600mW VTX w/ 40-channel coverage including RaceBand
- 7 - 42V input voltage, 2oz copper PCB ensuring the 120A maximum continuous current
- Reinforced solder pads of trouble-free direct soldering, extremely low profile design
- BetaFlight ready; 3-color LED board controlled by LED strip signal
Specifications
-STM32F303CCT6 32-bit processor with 256KB flash
-MPU6050 gyroscope / accelerometer
-ATmega328P with Adruino Bootloader ( minimOSD )
-Micro USB connector for programming
-BLHeli - S 20A ESC supports 30A burst current, Oneshot125 and DShot150
-2205 2500KV brushless motors
-8x 5040 3-blade propellers
-Wheelbase: 200mm
Options
BNF: with FrSky 16CH receiver, compatible with TARANIS
PNP: without receiver
Videos:
Review
Furibee Fuuton 200mm Mini Quad -Review - Tuning - Flight Test (11 min 55 sec)
MISC
Furibee Fuuton 200mm mini quad -Crash (1 min 28 sec)
Furibee Fuuton quick punch out... wow!! (0 min 39 sec)
Pictures:
Instructions manual with some good info here
Fuuton arrives in a well protected box
Front view
Side view
Side view
Rear view -does not come with the battery plate, you can pick these up for 3-4 bucks
Bottom View
LEDs & 600mw 40CH 5.8ghz VTX
Back side of LEDs
Powered on red LED's
Holybro Kakute F3 Flight Controller with integrated OSD and PDB
Plenty of space for additional hardware "receiver"
2205 2500kv motors CW & CCW + : BLHeli-S 20amp ESCs
5040 propellers- provide excellent power -havent crashed it yet, but when I do ill be sure to mention how durable or how not durable they are
*edit* was in a pretty bad crash today, these props are very durable, result was one bent prop.
Plastic action camera mount, fits snug on the top plate and is held on by zip ties. The mount hos slots allowing velcro straps to be placed
left to right as well as front to back
RHCP antenna with RP-SMA Male connector - attractive looking antenna, with a strong stem. Holds position very well
Review
First Impressions:
The first thing I noticed about the Fuuton when I picked it up was how incredibly light it was. This caught me off guard because it actually has 4mm thick main plate. Ive been reading about a new type of carbon fiber that is being used that is significantly lighter. Im guessing it was used here. Visually, everything looks to be of high quality, smooth and clean cuts that make for excellent fitment. Since an AIO FC with integrated OSD and PDB was used, it left the quad looking a little bare bones. A great aspect in my book, not only does it make the quad lighter, but it leaves room for other essentials, one of them is being able to fit a full sized receiver.
Frame
Great frame! the main plate is a huge 4mm thick while the top and side plates are 2mm. In total, the frame is made up of just 4 carbon fiber plates plus the 4 standoffs. I didn't weigh the frame by itself but it, along with the rest of the hardware are amazingly light. Just got into a crash today -a pretty bad crash: I throttled to 60-70% straight into the ground and only suffered a bent prop and broken antenna adapter. The side plates provide structural strength and doubles as the camera mount which is able to angle almost fully upwards. There are holes that fit foxeer and runcam or other similar cameras. Lastly, also included in this package is a plastic action camera mount, looks like it should be able to fit a gopro session, as well as other comparable cameras. I use a Hawkeye firefly 7S, it's a little too wide, I had to trim the mount probably 1mm to get it to fit.
Motors
the motors are 2205 @ 2500kv, these are also light weight, but produce big thrust. From the bottom of the stator to the top of the bell "bottom of shaft" it is just 40mm. That's a good bit less than most other 2205's out on the market.
Flight Controller & ESCís
The flight controller is a special one: Holybro Kakute v1.0, it comes loaded with betaflight v.3.0.1 -I think the current release is up to 3.1.6 -the good thing is that it is easy to update. This FC and ESC are able to run 4K/4K-not the best, but excellent nonetheless. I really like this FC, not only does it look great, but it performs great. the pads are just all in the right places, it makes for a clean looking install, I mean just look at the pictures, definitely cuts down on the wire clutter. For more info on this flight controller, click here I don't have too much info on the ESC's, just that they are 20amp, BLHeli-S and are capable of running everything from oneshot to multishot to dshot.
FPV Equipment
Image quality and range are just as good as any other FPV kits Ive used. The camera is a an HS1177 clone with a 2.5mm lens -it produces a clean, crisp image, colors are excellent, and works great in bright conditions. I have not tested it yet in dark conditions. The VTX is a 600mw , 40channel, 5.8ghz transmitter, which I think is overkill. Max you should use for a miniquad is 200mw. With that being said, the range is of course excellent, I havent had a full loss of picture yet.
Flight Performance
The Fuuton is nothing short of amazing, the extremely low weight coupled with powerful hardware results in a true monster. As you will see from the LOS videos I will be posting, this quad has an insane amount of power.
Pros
Frame-Super Light weight!
Powerful- Lightweight 2205 2500kv motors
Durable
Superb Hardware all around
Clean clear picture quality through HS1177 clone
Flat head frame screws - this is especially important for the bottom, in the event of a crash, the screw heads will mess up your lipos!
Comes with action cam mount
Cons
Doesnt come with battery plate
OSD requires FTDI adapter - kit doesnt not include one "its cheap though, you can pick one up for 2-3 bucks"
Final Thoughts
This is really a great quad, especially at the discounted price using the coupon. I think this quad was created with weight in mind, as it is among my lightest in this size. In addition to the low weight are powerful 2205 motors and 20amp esc's together provide an amazing power to weigh ratio that was almost too much to handle (can never have too much power). It has top notch hardware all around, even the included flight controller is something to be proud of. The Holybro Kakute, is a work of art itself, it looks good and is packed with features, like integrated PDB and OSD. Unfortunately it's not the fastest board, I was only able to get PID loop and gyro update freq at max 4k/4k, nonetheless, it's still excellent. The hardware is was installed onto a simple looking frame, that has a thick 4mm bottom plate and 2 mm top plate -that's able to take crashes with ease. The Fuuton is an amazing quad, it's become my favorite 200+mm and basically my faily flyer
zzz
Jan 18, 2017, 03:14 AM
Danq0's Avatar
Weights
Quad minus battery
to appreciate how light the Fuuton is, take a look at these other quads:
RX185 185mm frame @ 251g (+~40g for antenna and props)
190mm gb190 quite a bit heavier @ 335g (+~40g for antenna and props)
Velcro Strap
Action Cam mount
RHCP Antenna
Camera-HS1177 clone
Taranis X9D Setup
Furibee Fuuton 200 Taranis + Betaflight Setup! (23 min 22 sec)
Betaflight
See attached photos below
This is basically the stock dump, just with my changed pids and config settings.
Code:
# version
# BetaFlight/SPRACINGF3 3.0.1 Oct 18 2016 / 10:35:52 (48b7b4f)
# name
name -
# mixer
mixer QUADX
mmix reset
# servo
servo 0 1000 2000 1500 90 90 100 -1
servo 1 1000 2000 1500 90 90 100 -1
servo 2 1000 2000 1500 90 90 100 -1
servo 3 1000 2000 1500 90 90 100 -1
servo 4 1000 2000 1500 90 90 100 -1
servo 5 1000 2000 1500 90 90 100 -1
servo 6 1000 2000 1500 90 90 100 -1
servo 7 1000 2000 1500 90 90 100 -1
# servo mix
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature CURRENT_METER
feature LED_STRIP
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
# serial
serial 0 1 115200 57600 0 115200
serial 1 1 115200 57600 0 115200
serial 2 64 115200 57600 0 115200
# led
led 0 4,6::C:2
led 1 5,6::C:2
led 2 6,6::C:2
led 3 7,6::C:2
led 4 8,6::C:2
led 5 9,6::C:2
led 6 10,6::C:2
led 7 11,6::C:2
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
# aux
aux 0 0 0 1750 2100
aux 1 27 1 900 1250
aux 2 2 1 1750 2100
aux 3 12 2 1525 2100
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
# master
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interpolation = AUTO
set rc_interpolation_interval = 19
set rssi_ppm_invert = OFF
set input_filtering_mode = OFF
set roll_yaw_cam_mix_degrees = 0
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1040
set max_throttle = 2000
set min_command = 1000
set servo_center_pulse = 1500
set max_esc_throttle_jump = 0
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 0
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set disarm_kill_switch = ON
set gyro_cal_on_first_arm = OFF
set auto_disarm_delay = 5
set small_angle = 25
set fixedwing_althold_dir = 1
set reboot_character = 82
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autoreset = 1
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_coordinates_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set hott_alarm_sound_interval = 5
set battery_capacity = 0
set vbat_scale = 108
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set vbat_hysteresis = 1
set current_meter_scale = 500
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set max_angle_inclination = 700
set gyro_lpf = OFF
set gyro_sync_denom = 2
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set throttle_correction_value = 0
set throttle_correction_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_lowpass_enable = OFF
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set rx_min_usec = 885
set rx_max_usec = 2115
set gimbal_mode = NORMAL
set acc_hardware = AUTO
set acc_lpf_hz =  10.000
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 4
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SPIFLASH
set blackbox_on_motor_test = OFF
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set ledstrip_visual_beeper = OFF
# profile
profile 1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set pid_delta_method = MEASUREMENT
set yaw_p_limit = 500
set pidsum_limit = 700
set dterm_lowpass_type = BIQUAD
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set vbat_pid_compensation = OFF
set pid_at_min_throttle = ON
set iterm_throttle_gain = 0
set setpoint_relax_ratio = 30
set dterm_setpoint_weight = 200
set yaw_rate_accel_limit = 220
set rate_accel_limit = 0
set accum_threshold = 130
set yaw_accum_threshold = 32
set yaw_lowpass = 0
set pid_controller = BETAFLIGHT
set p_pitch = 55
set i_pitch = 40
set d_pitch = 22
set p_roll = 46
set i_roll = 38
set d_roll = 20
set p_yaw = 60
set i_yaw = 39
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 40
set i_level = 40
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity =  2.000
rateprofile 0
# rateprofile
rateprofile 0
set rc_rate = 144
set rc_rate_yaw = 145
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 74
set pitch_srate = 74
set yaw_srate = 74
set tpa_rate = 10
set tpa_breakpoint = 1500
MWOSD
Jan 20, 2017, 01:38 AM
nice looking frame, it's a got a really thick bottom plate so it should be able to handle crashes really well. I look forward to seeing some reviews on this one. Do you have any idea when this will be released?
Jan 21, 2017, 01:50 PM
Danq0's Avatar
my best guess is as good as yours, it says expected shipping date is JAN 30-FEB6. Unfortunately I think they do this when they dont have a stock of certain items.
Jan 21, 2017, 03:42 PM
Fan of just about anything RC
SoloProFan's Avatar
200 is a nice size, allows 5 inch props, and generally more room to install things on the frame. Just hope it uses a wider angle camera than the F180. And don't ship it with ancient firmware, like the Cleanflight 1.11.0 that was installed on the F180
Latest blog entry: For the love of the hobby!
Jan 23, 2017, 05:10 AM
Danq0's Avatar
yup my favorite size, I've tried all sizes smaller and bigger, and 190-220 is the size I always seems to come back to. Although lately Ive been wanting to get longer arms so I can use 6" props on these 200mm frames.
Feb 21, 2017, 06:58 AM
Available now~
Feb 21, 2017, 06:59 AM
We provide two free samples to review~
Reply here if you are interested in it
Feb 21, 2017, 07:36 AM
I am definitely interested, count me in
Mar 01, 2017, 02:44 AM
So at least a first review. Thanks AndyRC !
FuriBee Fuuton 200 - Its Brilliant (25 min 28 sec)
But 600mW not switchable
Mar 01, 2017, 03:52 AM
BossyAtBelgium's Avatar
Will the frame be available seperate? I like the looks of the frame very much and i'm very interested into getting this frame.
Grtz Bossy
Mar 01, 2017, 03:53 AM
SoloProFan's Avatar
Looks like a nice one, OSD, Dshot, I'm interested
Mar 01, 2017, 09:49 AM
Yes please
I would love to be one of the two to get a free sample. Is that possible?!
Mar 01, 2017, 12:58 PM
campfir3's Avatar
I'm definitely in for a sample for review if you have any left, let me know.
Mar 01, 2017, 01:19 PM
Would love to try this out. Saw Andy RC's review looks great
