Jan 17, 2017, 08:48 AM
New Product
Foxeer new cams arrivals: Arrow v3 HS1195 , HS1177 v2 , Monster v2 , Night Wolf v2
Foxxer just announce on thier face boot these 3 new cam, not too much info on them:
Arrow v3 HS1195 seems to be already available,
Upgraded:
5-40v input support
Cool blue metal casing, 2.5mm lens included (not extra 5$ like the arrow v2)
http://www.banggood.com/FOXEER-Arrow-V3-2_5mm-600TVL-HAD-II-CCD-PALNTSC-Mini-FPV-Camera-Built-in-OSD-MIC-p-1121696.html
HS1177 v2:
The legendary HS1177, will it get much better?
http://www.surveilzone.com/Foxeer-600TVL-HS1177V2-FPV-CCD-Camera-g-1715
On the v2 we get better voltage input range 5-40v improved board stability and the alloy case.
Monster v2:
This is the 1200TVL CMOS 16:9 cam which is supposed to be amazing, On v2 it now has an added OSD, MIC and Allu Case.
http://www.banggood.com/Foxeer-Monster-V2-1200TVL-CMOS-PAL-NTSC-FPV-Camera-with-OSD-and-Audio-p-1132704.html
Night Wolf v2:
The night time cam, will probably get an OSD as well, I didn't have so much luck with the v1....
UPDATE:
http://www.banggood.com/Foxeer-Night-Wolf-V2-700TVL-12-Inch-CCD-FPV-Camera-PAL-NTSC-Built-in-OSD-Audio-p-1133894.html
Foxeer Night Wolf V2 0.0001lux starlight FPV camera, adopt 1/2" industrial sensor,
upgraded to alloy case with easier installation, add OSD and audio, over 100 degree angle, perfect for nigh flying!.
I wish they will add 2.3mm lens like the runcam swift 2 option (didn't test yet, but two landed today )
On the Arrow v3 picture i didn't see the MIC hole in front, i wonder if they moved it back to handle the wind interference like on the runcam swift 2
More info to come....
Jan 17, 2017, 08:51 AM
Reserved
Jan 17, 2017, 08:52 AM
Reserved 2
Jan 26, 2017, 05:57 PM
Can anyone tell me how the performance of the monster is? Does the widescreen high 1200TVL resolution create latency in the video feed?
Jan 26, 2017, 05:59 PM
Mitchie's Avatar
I don't know, but mines on the way!
Jan 27, 2017, 10:16 AM
parajared's Avatar
I like the Monster. I think it yields a better image than the 1177, no latency noticeable to a crotchety old codger like myself. "Get off my lawn ya d*mn kids!" Also I'm in my 30s.
I crashed a plane and ordered another "XAT 1200m" and when I opened the box I had a Foxeer Monster (presumably v1) inside so I assume Monster and XAT are the same thing. The image looks exactly the same. Also it came with a removable OSD menu clicker-thinger.
Feb 24, 2017, 02:55 PM
monster v2 is comming, i have my source i can confirm the add of osd + mic
Feb 24, 2017, 07:21 PM
LoS sUAS AP/V is not a crime
If the Arrow v3 was available in lime green I would order it right now.
Feb 24, 2017, 07:38 PM
The Monster is a great camera and a Voltage readout like the Arrow has would lock it in for me. Very smooth video and latency doesn't exist.
One thing to keep in mind. You do lose some vertical FOV compared to the Arrow. I've tested this using the same Foxeer 2.5mm lens. May be a concern to some Quad pilots.
Feb 25, 2017, 08:36 AM
yes it s hard to land now
Feb 26, 2017, 02:12 PM
When is the Monster V2 coming? I need a cam, I just cancelled my Runcam Swift 2 order.
Feb 27, 2017, 12:39 AM
Monster V2 should be available within 1 week
Feb 27, 2017, 11:07 AM
Source?
Feb 27, 2017, 02:38 PM
Wanted to get a 16:9 cam for my first FPV quad build and the Monster caught my eye. Read that a V2 was coming out so I thought I'd contact Foxeer about release date
From Snow at Foxeer: "Monster V2 should OK this week, many stores will stock"
Mar 04, 2017, 04:19 AM
Originally Posted by Mr.Serious
Source?
commercial from surveillzone
