DShot will be my next project. It doesn't look too hard, but the signal wire from motor four will need to be moved from it's current location to the LED rx pin and remapped in betaflight. You will need to be on betaflight 3.1.x to do this since resource remapping was a new feature for 3.1.x. The new resource command makes this possible allowing us to customize the resource allocation for just about anything you need. Not sure why this is even an issue for this Femto FC, but it is and this has to be done to get motor 4 working under DShot. Here is the Github page to describe the remapping process in betaflight https://github.com/betaflight/betafl...e-Command-(3.1) I'm currently using multishot at 32k with motor PWM speed separated from PID speed turned on. |
I'll get you a screenie if you haven't by the time I get home. Around 6pm EST.. |
Requesting a scan of the owner manual please!
Hi Folks. This is a big THANK YOU to the owners of the Babyhawk who are giving us all these welcome early reviews, tips and pictures
![]() I have a request though, could someone please attach a scan of the owner manual if possible? Thanks! |
I can do that too when I get home. It's only useful for how to configure the VTX...
Is it something like the TBS unify where it only supports "legal" bands out of the box and you have to perform some type of button combination to unlock it? |
Seriously though.... Would be cool if you could unlock it... |
Just received mine last night but still haven't been able to fly. I initially thought about going the XSR route so I could have telemetry but decided to go with the XM+ receiver instead.
Really good fit and finish and the quality of the motors is awesome; can't wait to get into the air. Also looking forward to getting one of their power packs with the Board, ESC, and Motors to build another small quad like an Airblade Creampuff or something similar. Emax is killing it right now. |
Sent from my SM-G9287 using Tapatalk |
In case someone has never installed a Sat rx on the Emax Femto here is a Good video of the steps to install it on the Babyhawk.
It's a better signaling protocol, but how much better flight performance it gives is hard to define. If the PWM signal is prone to noise DShot would be a lot better. If the the PWM signal was very clean, probably not much difference in flight. |
