Leopard 8072-10t 175kv Airplane Motor - RC Groups
Here is a brushless motor from a company with over 15 years of manufacturing experience.
Leopard Brushless Motors adhere to the highest quality standards.
From Leopard Motor Company:
Leopard Motors are precisely constructed using the most advanced CNC components. Leopard Power Model Co. has over 15 years experience manufacturing high quality precision hardware. The focus is on ensuring the consistency of their products. Constructed from beautifully anodized aluminum alloy and top-quality components, Leopard motors deliver optimum performance, quality, and reliability at a price much less than many other premium motor brands on the market today.
The Airplane brushless motors features a long shaft which extends past the rear of the motor, allowing the user to either use the included bolt-on prop adapter for traditional mounting, or reverse the shaft for front-mounting applications.
Each motor has pre-installed male 4.0mm bullet connectors and an accessory pack with a matching set of female bullet connectors for your ESC, an X-mount plate, and a bolt-on style threaded prop adapter.
Features
  • Cost is $129.99
  • Lightweight design uses reinforced materials for high-speed operation under constant conditions
  • High efficiency and low running temperatures
  • Built from top-quality materials with premium imported bearings
  • Dynamic balancing accuracy of at least 99%
  • Hand wound
  • High overload capacity
  • Excellent heat dissipation
  • Designed to endure the most demanding applications
  • Long service life with minimal maintenance required
Specs
  • KV: 175
  • Lipo cells: 6-13s
  • No load current (7.4v): 1.6A
  • Max current: 90A
  • Watts: 2860W (See chart linked below)
  • Resistance: .023 ohm
  • Prop adapter shaft size: M12
  • Motor shaft diameter: 12.0mm
  • Dimensions: 80.0 x 72.0
  • Weight: 1098g (motor only) | 1288g (w/ prop adapter & x-mount)**
  • Prop: 18x10 - 22x10
  • Max Pull: 13.4kg
Photos
Warranty
All Leopard brushless motors come with a 240-day warranty from the time of purchase. If an issue is found to be the fault of a manufacturing defect with the motor. We will replace the item or refund the original purchase price on behalf of Leopard Power Model Co.
Learn More
Head over to Altitude Hobbies to learn more about this motor.
Jan 10, 2017, 08:57 PM
Thelongranger
deltapilot's Avatar
Figured it would be a lot more expensive
Jan 12, 2017, 05:50 PM
Closed Account
I was surprised by the power output. My Himax 6330-210 has better output and is almost 400 grams lighter. I'm currently running a 20.5x14 on my Himax with 10S
Jan 15, 2017, 01:07 PM
9XTremist's Avatar
at exf3bguy,
I only have 1 Leopard motor, a 4250, a lot smaller but this motor is 80mm dia. x 72mm long yours is (whether it's the old or new 6330) is 63mm x 67mm, I would hope it's lighter. This motor puts out (according to the above) 13.4kg of thrust, 29.5 pounds of thrust. What does the 6330 put out? The 6330 is a very popular F3A motor but I couldn't find any thrust specifications only rpm at voltage readings and my prop/rpm/thrust calculator didn't go to a 20" or 21" prop.
Jan 15, 2017, 05:31 PM
Closed Account
Not very scientific but I have been flying IMAC and F3A for a long time. In both disciplines a power to weight ratio of 2:1 is pretty standard. That being said, the Himax has to be around 24lb to 27lb of thrust. My current F3A airplane is heavy at 12 lbs ( converted from YS power ) but the Himax gives me unlimited vertical. I may be wrong here but I would expect the 80mm outrunner to be in the same power class as a 50cc-60cc gasser.
