Jan 07, 2017, 08:44 PM
Hitec X1 mini connect error check main port
hi all..
brand new (2 days) X1 mini charger, brand new batteries (2s-4s) all come up with "connect error check main port" after a few seconds when i try to charge them.
my other charger is fine, the batteries are either xt60 or deans so it's not the little banana adapter cable.
Any ideas what to check because the manual just says "battery connection wrong" with ZERO hint as to which port it is.
the battery reads fine with the battery meter it reads all the cells and also the (really bad) charge master software controls and reads the cell voltages correct.
i'm kinda screwed as we have our first multi GP race this weekend and i was hoping to get some practice in before tomorrow afternoon
Jan 07, 2017, 09:32 PM
with and without the balance lead connected
Jan 09, 2017, 12:23 PM
Fully Sending It
Xpress..'s Avatar
Try disabling the cell warning function:
-Navigate to the System Settings menu
-Enter into the menu, then locate a menu called "Bal. Connection"
-Turn the function from ON to OFF
Then try to charge again.
Jan 09, 2017, 02:33 PM
i've tried that.... tried factory reset. still the same. it has to be a hardware error. my other hitek X1mini charger has no problems.
Jan 09, 2017, 05:56 PM
Fully Sending It
Xpress..'s Avatar
Where are you located?
Jan 09, 2017, 06:07 PM
daytona beach fl
Jan 09, 2017, 06:27 PM
Fully Sending It
Xpress..'s Avatar
daytona beach fl
Give us a call and we can help you out:
858 748 6948
Jan 09, 2017, 06:31 PM
858 748 6948
awesome. i will do that tomorrow, thanks
Feb 01, 2017, 01:42 PM
I bought 2 of these chargers last year and have the same problem you're having with both of them. I have tried 12 differnt batteries on both chargers, 2 of the batteries were brand new out of the package and still would get the error. It does this funny thing were they will start charging fine but then the voltage and amps start jumping up and down like crazy and then the error.
By any chance did you find out what the problem was ?
Thanks Tim
QUOTE=cblackburn1099;36589052]hi all..
i'm kinda screwed as we have our first multi GP race this weekend and i was hoping to get some practice in before tomorrow afternoon [/QUOTE]
Feb 01, 2017, 02:26 PM
Fully Sending It
Xpress..'s Avatar
Thanks Tim
With the voltage and amperage jumping up and down like you describe, there is definitely an issue inside of the chargers. Get them to us and we'll take a look.
http://hitecrcd.com/support/warranty-service
Feb 03, 2017, 06:33 PM
I sent out one of the charges today (couldn't find a receipt for the second one). Thanks for your help.
Tim
Feb 06, 2017, 12:47 PM
Fully Sending It
Xpress..'s Avatar
Tim
We generally aren't super strict on warranty related things, I would still get the other charger to us.
Dec 13, 2018, 06:09 PM
I pulled my Hytek X1 Mini out after a few months of non use. All of my batteries show “connection break” on the display screen when attempting to charge them. Tried factory reset and made sure balance charging was switched on with no joy. The unit is two years old and had worked flawlessly when I last used it. Very strange. Unfortunately, I’m well out of the one year warranty period, so I THINK I am SOL. Anyone have any clues?
Dec 13, 2018, 07:11 PM
Fully Sending It
Xpress..'s Avatar
Originally Posted by motorradmike
I pulled my Hytek X1 Mini out after a few months of non use. All of my batteries show “connection error” on the display screen when attempting to charge them. Tried factory reset and made sure balance charging was switched on with no joy. The unit is two years old and had worked flawlessly when I last used it. Very strange. Unfortunately, I’m well out of the one year warranty period, so I THINK I am SOL. Anyone have any clues?
What is the cell count on the packs?
We had a number of people return the charger to us with this issue, only to discover they were not using 6-8 cell NiXX or 2-4S LiPo.
Dec 18, 2018, 09:03 AM
Hitec X1 mini
Good point, but I only have 2 and 3S LiPo packs. All the packs are in good condition.
I corrected my original post to reflect the error message actually showing, to: “connection break”.
