Sep 29, 2004, 10:25 AM
Will HS-55 servos work with Multiplex Twin Jet?
I already have some new HS-55 micro servos. Will it be enough power the wings of a Twin Jet from multiplex?
Sep 29, 2004, 11:45 AM
yes :-)
Sep 29, 2004, 11:53 AM
Thanks. I went ahead and ordered some HS 81s just in case.
Sep 29, 2004, 12:23 PM
Pushing HS55s a bit. Not the power so much as the strength of the servo gears.
Sep 29, 2004, 12:26 PM
vintage1's Avatar
es. If you end uop fliping backwards into a tree or doing cartwheels its a toss up as to whether teh geras will stripo or the horn break. Done both. If you use the bigger meatier horn on the 55 the gears strip. Get several sets of these
I fly 55's almost exclusively, but my picojet has bigger ones. I think 81's.
Sep 29, 2004, 12:34 PM
Jurgen Heilig's Avatar
I use the HS-55 in my twin BL powered Twin Jet - no problems over the last three years. Now I would go for the new HS-56 instead.
Jürgen
Sold Multiplex Funjet with LS ParkJet Motor, Prop Adapter and 2 HS-55 Servos (All NIB) JohnM Aircraft - Electric - Airplanes (FS/W) 0 Jun 13, 2007 08:55 AM
would hs-300 servos work with eco 8? newbflyer1 Electric Heli Talk 4 Jul 22, 2002 02:21 AM
Anybody use HS-55 Servos with the GWS R4-P Receiver? mrebman Parkflyers 9 Sep 22, 2001 05:08 PM
Will the Hitec HS-80 Servos work in the Litestick or Duskstik? mrebman Parkflyers 3 Sep 07, 2001 11:03 AM
will HS-80 gearsets work in HS-81 servos ericstac Power Systems 3 Jun 01, 2001 03:16 PM
