Jan 06, 2017, 03:50 AM
FrSky-MKT
New Product
FrSky New Arrival - XSRF3E
The second flight controller of FrSky!XSRF3E, which integrates XSR and F3E. Here we go!
Free Test Link:https://www.rcgroups.com/forums/show...ee-Test-XSRF3E
Overview:
Description: Name: TOP.png
Description:
TOP
Description: Name: BOTTOM.png
Description:
BOTTOM
Specifications:
•Dimension: 36×36×6mm (L × W × H) with 30.5mm mounting holes
•Hardware: STM32F303 CPU (72Mhz inc FPU), MPU9250 (accelerometer/gyro/compass), and
BMP280 barometer for F3E
•Weight: 6g
•Channels: 16CH (8CH is RSSI) by SBUS to UART2 Rx of F3E, Smart Port of XSR to UART3 Tx of F3E
•Operating Voltage Range: 4.0~10V
•Operating Current: 200mA@5V
•Compatibility: FrSky Taranis X9D/X9D-Plus/X9E/ Horus X12S/XJT in D16 mode
•Firmware Upgradeable
Features:
• Built-in F3E and XSR receiver module
• Features the latest Accelerometer, Gyro and Compass and Baro sensor technology
• XSR receiver is a full duplex telemetry receiver, it will receive the commands of radio and send to F3E by SBUS (8CH is RSSI) to UART2 Rx of F3E, it can also send telemetry information back to radio by smart port
• After configuration, you can use the FrSky X9D/X9D-Plus/X9E radio (wireless) to set the PID parameters for XSRF3E
• 6 PWM output signal lines for ESCs and Servos. Arranged for easy wiring on standard pin headers
Software:
•The F3E runs the open-source Cleanflight/ Betaflight flight control (FC) software and firmware upgradeable
(SPRACINGF3EVO), the factory firmware is betaflight_3.0.1_XSRF3E
•The XSR receiver runs the software which was developed by FrSky and firmware upgradeable
XSRF3E FrSky LINK:http://www.frsky-rc.com/product/pro.php?pro_id=176
Retail Price (tax excluded): US$ 42
FrSky hope you have found this useful and have a nice day guys!
Jan 06, 2017, 08:25 AM
It is a good idea to rename the thread - FrSky.......
Jan 07, 2017, 11:33 AM
Alex
Datos's Avatar
My small preliminary review: HERE
Jan 08, 2017, 10:07 AM
Does the telemetry output the internal sensors of the XSRF3E?
Where would I connect on XSRF3E the to get S-Bus output to get some more channels, the specs. says it is a 16 channel receiver? Is the "UART" in the upper right UART 2?
Jan 08, 2017, 10:34 AM
Alex
Datos's Avatar
Seems to be so. You should get telemetry values from F3E to Taranis.
UART or UART2 - it is not clear. Should be checked. Maybe that it is UART2 or UART3. But both shoud be busy - UART2 used for receiver and UART3 for telemetry.
I don't really think that you can get the SBUS channels out of the receiver for external devices. Only through PWM outputs of F3E, unless you would find the trace that carries SBUS to F3E and take it in parallel from there.
Jan 08, 2017, 08:21 PM
The SP Racing F3 EVO has 3 dedicated UARTS; UART 1, UART 2, and UART 3. If the one that is marked UART is UART 2 then with some luck the Rx pin would be S-Bus out from the receiver part. (I hope, as I want another channel).
I have never seen unnumbered UARTS (when there is more then 1) or ones marked "0" . So I am cautiously optimistic; but I could be wrong.
What I found interesting however Frsky refers, on this receiver + controller, to a F3E controller, not a F3 Evo (liked they did on the F3EVO like they did on the XMPF3E.
Either way I want at least one.
PS. DATOS, I really like that Blue Frsky transmitter.
Jan 10, 2017, 03:39 AM
FPV addict
mlilasic's Avatar
This (and 4in1 ESCs) will enable us super clean builds of which I am fan. Subscribed.
Jan 18, 2017, 10:21 AM
Alex
Datos's Avatar
Some edits to my review of XSRF3E and XMPF3E. Added telemetry description
READ
Jan 25, 2017, 07:41 PM
FPV addict
mlilasic's Avatar
Full Review in progress - FrSKY XSRF3E - F3Evo Flight Controller with integrated full telemetry XSR receiver:
https://www.rcgroups.com/forums/show...y-XSR-receiver
Jan 26, 2017, 03:42 AM
FPV addict
mlilasic's Avatar
Hi, does integrated XSR in XSRF3E combo uses some special XSR FW or standalone XSRs FW can be used?
Update:
XSR in XSRF3E combo uses special XSR FW, get it from here:
frsky web - FW tab
Jan 26, 2017, 04:45 AM
Alex
Datos's Avatar
There is nothing on frsky web in FW tab
No. It has its own FW. If you flash it with regular XSR FW - you'll no longer be able to bind and might burn down your RX
Jan 26, 2017, 04:51 AM
FPV addict
mlilasic's Avatar
Thanks for quick answer. Do you have or know where I can find nonEU FW for it?
Jan 26, 2017, 05:03 AM
Alex
Datos's Avatar
You should wait for the CNY to end (5th of Feb), PM me and I'll get the FW for you from FrSKY. I have XSRF3E FCC version but there is no way to make a dump for you.
Jan 26, 2017, 05:28 AM
FPV addict
mlilasic's Avatar
Ok. Thanks.
Jan 30, 2017, 11:46 AM
Alex
Datos's Avatar
My setup photos:
Frame: KDS Kylin 210
Cam: Foxeer 700TVL
VideoTX: 5.8Ghz DalRC 600mW
Antenna: clover, Aomway
Flight board: FrSky XSRF3E (F3Evo with built-in XSR)
Power DB: FlyMod.net BEC/ZMR
Motors: KDS Kylin 2204 2300kv
ESC: KDS Kylin 20A OneShot125
LiPO: FlyMod.net 1,300mAh, 4S, 45-90C
Props: 5x4x3
Total weight (everything except LiPO): 300g
