Jan 09, 2017, 09:21 AM
Ali Machinchy: Snr PD Hangar9
Originally Posted by tailskid2 View Post
No, sadly I didn't.....the Horizon display had two of them on display...the one with the gasser was on floats and the other one was electric powered......I could not see putting in an electric motor as the flight time would kill me - the Stick's are just one fun airplane and 6 minutes of flight is just getting me started.
I did notice they used those long metal servo arms on the flaps & ailerons. The control horn on the elevator is on the top side so it will be a pull to get up elevator.
Can't wait to get mine!!!!
The Long servo arms are in order to get the 3d movements. Also big crow braking effects. You can get away with shorter if you want.. However. Its so much fun with huge flap deflections
Jan 09, 2017, 10:46 AM
tailskid2's Avatar
Can you verify the measurement of the firewall?
Jan 09, 2017, 11:35 AM
Originally Posted by Ali Mach View Post
2lbs 16 oz.
isn't that really just 3 pounds?
Jan 09, 2017, 11:56 AM
It is indeed.
Jan 09, 2017, 11:57 AM
99mm wide
105mm tall
Jan 09, 2017, 02:17 PM
tailskid2's Avatar
Thank you!
Jan 09, 2017, 02:28 PM
No problem at all.
Jan 09, 2017, 03:51 PM
Cuure's Avatar
Can't wait. Here is my old stick with a 40 twin on it.
Giant Big Stik DLE 40cc (2 min 4 sec)
Jan 09, 2017, 08:14 PM
Crowfly's Avatar
99mm wide
105mm tall
I got a Zenoah G 26 that'll fit on that. Kinda heavy though at 3#12 OZ. But it's got me considering. I bet it would be a fairly good combo.
Jan 10, 2017, 08:03 AM
I don't think the weight is too much of an issue. I have 4.5lbs hanging from the front with the saito radial. Power would not be stellar with the 26, but I am sure enough to fly. One of my test beds has a saito 30 on the front. It flies it, and is fun in its own special way. Far from unlimited.
Regards Ali
Jan 11, 2017, 03:30 PM
shaftbass's Avatar
2lbs 16 oz
It is indeed.
This made me chuckle.
I am ordering one. Still deciding on which engine.
Jan 11, 2017, 03:33 PM
brilliance on ali's part here.
Jan 11, 2017, 05:23 PM
shaftbass's Avatar
Just placed my order!
Jan 12, 2017, 03:12 PM
Life is better w/ RC
kman712's Avatar
Hey Ali
Is there any performance difference on the 33gx when using the single pipe version on the pits muffler vs the double pipe version? I see that HH sells both.
Jan 12, 2017, 03:25 PM
Originally Posted by kman712 View Post
Hey Ali
None at all. That I noticed.
Regards Ali
