Hitec Phantom X4 Charger - RC Groups
If you are a Phantom 3 or 4 owner and have lots of batteries, then the new Hitec Phantom X4 Charger is right up your alley...
4 Port Charger for your Phantom
If you are a Phantom 3 or 4 owner and have lots of batteries, then the new Hitec Phantom X4 Charger is right up your alley. It's a 4 port charger that can simultaneously charge your batteries. It can also put them at storage voltage or even cycle the packs to break them in. It also has two USB ports with 2.1A output so you can charge up your tablets, phones, or transmitters at the same time. It's an AC only charger so you'll need access to a 100-240AC power outlet and it weighs 7 lbs but there is a nice carry handle that makes transporting the charger around a breeze. Pricing is said to be $224.99, no word on availability yet. The charger is not listed on Hitecs website as of this writing, but keep eye out at HitecRCD.com for more info.
Specifications:
  • AC Input: 100-240 Volts AC
  • Total Charge Circuit Power: 100W x 4
  • Charge Current Range: 6.0 Amps
  • USB Output: 5V/2.1A x2
  • DC Output: 19V/2A x2
  • Three Charge Modes: Charge/Storage/Cycle
  • Size: 10 x 5.6 x 7.1 in (255 x 142 x 180mm)
  • Weight: 7.1 lbs. (3.22kg)
Jan 06, 2017, 12:09 PM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
looks like an upgraded version of Venom's.
Jan 06, 2017, 02:15 PM
BuffaloJustin's Avatar
It's a SkyRC 4P3 clone.
http://www.skyrc.com/index.php?route...product_id=228
Really nice charger for P3 and P4. The rumored Hitec version pricing is probably correct, as that's about what the SkyRC one costs:
https://hobbyking.com/en_us/skyrc-4p...batteries.html
Jan 06, 2017, 03:03 PM
I'm sure the hitec rep we be along shortly to explain to us that it is totally different from the skyrc one and built with their secret sauce like all their other skyrc based chargers. or something like that.
but if tower carries it you can probably get it for less than the skyrc one and get better support so it is probably the better deal. at least that's what I've found with their other chargers.
Jan 07, 2017, 04:07 AM
I Should Have Known It
Mad_angler1's Avatar
Nice looking bit of kit this, I posted about the P4 one a while back in the owners thread but not seen on in the flesh yet.
Jan 09, 2017, 02:44 PM
Xpress..'s Avatar
It's manufactured by SkyRC to our specifications, same as all of the chargers SkyRC manufactures for us.
Jan 09, 2017, 03:36 PM
Certainly. I didn't mean "clone" in any pejorative sense... just that it's all but identical. Perhaps I should have said "it's a SkyRC 4P3 twin" ?
Mar 07, 2017, 07:28 AM
I wish it had a 12V input option.
