Jan 03, 2017, 07:37 PM
New Product
Syma X5UC Hover Camera Quad 2.4G 6-axis Gyro RC Drone Quadcopter Ready to Fly
Syma X5UC & X5UW Wifi & FPV HD Camera Quadcopter Review (16 min 6 sec)
http://www.xheli.com/56h-x5uc-headless-sd.html
Syma RC introduces its latest X5UC Quadcopter! If you are familiar with the X5 series of quadcopters, the new X5UC is its enhanced sleek and slim race version. Lighter, sleeker, and faster is what the new design is all about! The electronics have also been upgraded with new features and a better quality camera.
A quadcopter is a machine that is lifted and propelled by four rotors. Unlike most helicopters, a quadcopter use symmetrically pitched blades mounted on four motors to produce lift. Controlling the speed of these individual motors allows the machine to move forward and backward, up and down, strafe left and right, and rotate clockwise and counterclockwise.
The Syma X5UC 4 Channel quadcopter brings a new element to radio control quads and offers a completely different experience of flying. It offers a refreshing change on how to hover, balance, and control a copter. With the help of an 6 axis gyro, stability and agility is achieved effortlessly. Flying the Syma quad is simple and intuitive allowing the pilot to enhance their skills quickly. Once you enhance your skills enough there are stabilization settings built in that you can disable to advance your ability to fly the X5UC and perform 360 degree flips. The X5UC is also equipped with an HD camera to capture all your flying adventures. You can also record pictures and video while saving to the included 8GB SD card.
Now equipped with Headless and Hover Mode! The headless mode features means that once this mode is activated, pulling the direction of the stick back towards you will bring your aircraft back home to you no matter is orientation, front, back, or side. This makes flying back to yourself when you lose sight of it much easier. The hover mode allows the quadcopter to hover in one spot allowing the flight control to take over and achieve altitude hold. Now you don't have to keep adjusting throttle as much while you are recording or flying smoothly.
Another special feature of the X5UC is the new push button take off and landing features. With a push of a button the quad will perform a smooth take off or landing without touching any of the joystick controls.
With the use of 2.4ghz technology the Syma X5UC radio system has the benefit of longer control distance, strong anti-interference technology, low power consumption, and rapid response times. Using spread spectrum technology for further remote distance, best anti-interference ability, least power consumption. you could fly more helicopters at the same time, its reaction speed is 100 times faster than other radio control.
The Syma Radio Control brand is one that is very well known in the micro helicopter industry. Its quadcopters has been a hot seller mainly because of its stability and ease of flight. The Syma X5UC Quadcopter carries all of these favorable traits over from the other quads to produce a quadcopter in an awesome ready to fly package.
The Syma X5UC comes ready to fly with two 3.7v 500mah Li-Po battery and charger providing about 7-9 minutes of flight time per charge.
Main Features:
Low-voltage protection
Over-current protection
Level calibration function
3D overturning function
With orange and green LED light
Pressure hovering height adjustment function
1 mega pixel camera w/ 8GB SD Card
Aerial photo-taking / video recording function
Fine tuning function
Fling-fly action
Headless mode
Left and right hand throttle mode switch
Auto take off and landing feature
Specifications:
Brand: Syma
Item No.: X5UC
Version: RTF
Quad Size: 12.6 x 12.6 x 2.76 inches
Charging Time: About 130min
Flying Time: 7 - 9min
Frequency: 2.4GHz
Gyro: Built-in 6 Axis Gyro
Channel: 4
Camera Pixel: 1MP
Control Distance: About 100m
Battery: two 3.7V 500mA Battery
8gb Memory Card
Required to Fly:
4AA Batteries
Jan 06, 2018, 05:19 PM
Jake From Planet Mascoutah, IL
Jake8131's Avatar
If you don't like the tx that comes with unit, use the one from x5HC and it will work fine.
