Thread Tools |
This thread is privately moderated by jj2003, who may elect to delete unwanted replies. |
Trader Rating: 9
Sold
F.S. 2 (two) MGM TMM 40063-3 X2 SPEED CONTROLLERS
(2) MGM TMM 40063-3 X2 controllers.
Full specs https://www.mgm-controllers.com/race...x2-series.html Basic Parameters Max RPMs 250.000 Max. peak current (peak 5 sec.)500 AMPS Max. continuous current (for full throttle) 400 AMPS Number of Li-Pol, Li-Ion feeding cells IV. 15 Possibility of motor temperature measuring (motor protection) Internal Data Logger (data recorder) Detailed programable parameters Empty batt. behaviour - instant motor cut-off Yes Setting of the range of neutral zone Yes Possibility of switching reversible controller into "one-way" mode Yes Reversible controller (both-way mode) Yes Bidirectional "both-way" mode Yes ACL - Automatic Current Limiting Yes ACR - Automatic Current Reduce Yes Temperature fuse of the controller Yes Current fuse of the controller Yes False-start protection Yes Masking of interference Yes Software reversal of rotation Yes Empty batt. behaviour - motor power reduction Yes Adjustable deceleration speed Yes Adjustable acceleration speed Yes External signalization of important states Yes Possibility of connecting plane position lights and flashing lights Yes Active free-wheeling circuit ON / OFF Yes Possibility of automatic setting of throttle limits Yes Possibility of manually set timing Yes Automatically set timing Yes Manually set type of cells Yes Possibility of manually set number of cells Yes Possibility of automatic setting of cut off voltage Yes Possibility of setting switching off voltage Yes Possibility of setting an amount of residual energy for BEC No Possibility of setting the voltage of BEC No Possibility of very powerful switching BECs No Possibility of setting current limits Yes Possibility of setting RPM limits Yes Possibility of motor temperature measuring Yes Possibility of cells temperature measuring Yes Outstanding cells management Yes Very high resistance against overloading Yes Plug and Play (functional immediately without the need for additional programming) Yes ICS-2 connector - super-fast PC connection link Yes Programming using PC Yes Reading-out of data from the controller using PC Yes Software updates available through internet Yes Telemetry (back data transfer) Yes Real-time Monitoring (PC or other device) No Internal Data Logger (data recorder) Yes Possibility of design with ON/OFF switch (connected safely) Yes Possibility of WR version (full protection against water) Yes Possibility of WP version (increased protection against water) Yes Possibility of design with external heatsinks + FAN Yes Possibility of design with water-cooled heatsinks Yes Possibility of design with external heatsinks Yes Length of the servocable 190 [ mm ] Servocable cross-section 0.25 [ mm2 ] Length of the power conductors see guide [ mm ] Power conductors cross-section to batt. / to mot. see guide [ mm2 ] Weight incl. all conductors see guide [ gram ] Weight without power conductors 460 [ gram ] Dimensions with external capacitor see guide [ mm ] Dimensions see guide [ mm ] Max RPMs 250.000 On-state switch (FETs) resistance at 25 °C 2 0.53 [ mW ] Motor PWM frequency VIII.32 [ kHz ] Number of regulation steps 2048 BEC short circuit protection No Max. BEC current at 25 °C No Switching HV-BEC voltage No Switching S-BEC voltage No Available BEC / OPTO versions OPTO Max. peak current (peak 5 sec.) 500 [ A ] Max. continuous current (for full throttle) 400 [ A ] Operating voltage XII.63 [ V ] Compatible with all types of feeding cells Yes Number of A123 feeding cells V.17 Number of NiCd, NiMh feeding cells 15 - 44 Number of Li-Pol, Li-Ion feeding cells IV.15 "One-way" mode Yes Possibility of setting current limits Yes Possibility of setting RPM limits (motor protection) Yes Possibility of motor temperature measuring (motor protection) Yes Possibility of cells temperature measuring (cells protection) Yes 4 Memory Banks Yes 32-BIT SYSTEM Yes Automatic Sensor Setting Yes Possibility of operation also with sensors motors Yes Real-time Monitoring (PC or other device) No Telemetry (real-time back data transfer) Yes Internal Data Logger (data recorder) Yes Splitting them up individually. BOTH ARE NEW, NEVER USED $825 each Paypal shipped lower 48 only $800 each U.S Postal money order lower 48 only I will ship overseas, but buyer pays actual shipping charges I will sell the CC cable and USB connector separately to the 1st buyer who wants it for an additional $25 One is a 6 wire leads to motor, one is a 3 wire lead to motor. Both have the same configuration as indicated below with the exception to the # of power leads to motor. This is a copy of the actual invoice for what I paid for one with 6 motor leads. I have one usb programming cable AND a cc11 connector for them. TMM 40063-3 for Race Boats X2-SERIES SKU MGM-TMM-40063-3B USBCOM4-device for controller connection with PC: No CC11-connecting cable between controller and USBCOM4: No Telemetry (back data transfer: Yes Battery Temperature Measuring (available for OPTO version only): No Motor Temperature Measuring: Yes Possibility of operation with sensors motors: No On-Off Switch: Yes WP version (increased protection against water): Yes WR version (full protection against water): No Design with Active Fan Cooling (2 x FAN): No Design with Water-Cooled Heatsinks: Yes Basic design with MP Jet 5.0 outputs directly on PCB (incl counterparts): No Power Conductors 10.0 mm2: No Power Conductors 16.0 mm2: Yes Design with 6 power conductors to motor (recommended for Lehner Motor): Yes Design with axially placed capacitors and power conductors (cables): Yes MP Jet 1.8mm (recommended for integrated AntiSpark: Yes MP Jet 5.0mm (male + female) 5 Sets: No MP Jet 6.0mm (male + female) 5 Sets: No MP Jet 8.0mm (male + female) 5 Sets: Yes Please solder these connectors to controller: Yes BARE CUSTOM $729.28 $940.90 Subtotal: $940.90 Shipping cost: $12.65 Grand total: $953.55 |
