Jul 23, 2017, 01:25 AM
Youtube channel : solentlifeuk
solentlife's Avatar
Having an absolute b all with this baby ....
Hobby King G&G MIG29 22 July 2017 (5 min 8 sec)
Cheap fun ...
Nigel
Jul 23, 2017, 01:33 AM
solentlife's Avatar
I have the general parts traced out onto Depron sheet .... just in case !!
Thinking about maybe an EDF modified version ? A 50mm with a decent 5000kv, 5 blade and 3S should get her going ...
Nigel
Jul 23, 2017, 01:55 PM
solentlife's Avatar
MIG29 G&G 23 July 2017 (4 min 45 sec)
Jul 29, 2017, 01:08 PM
solentlife's Avatar
I shall be testing 4S on this baby ... see what happens !!
4S 1600 35C weighs similar to the 3S 2250 I use.
Nigel
Jul 31, 2017, 05:13 AM
solentlife's Avatar
No way with existing stock ESC - it cuts out with 4S
No surprise actually.
I will swap out later to a 50A ESC and see what happens ...
Nigel
Sep 07, 2017, 01:10 PM
solentlife's Avatar
Glue and Go MIG29 via headcam 07 Sept 2017 (9 min 29 sec)
Amazing
Nigel
Oct 01, 2017, 10:07 AM
solentlife's Avatar
Hobby KIng Mig 29 flight one 30 Sept 2017 (8 min 51 sec)
Hobby King MIG 29 Flight 2 Cirava 30 Sept 2017 (11 min 43 sec)
Dec 01, 2017, 02:54 PM
solentlife's Avatar
Just knocked up another Mig 29 in 6mm Depron ..... stiffened with 2mm CF rods.
Fuselage where G&G uses two foamboard sandwiched ... I used 3 Depron ... and then thinned where tabs engage matching holes.
I moved motor forward and used the common 2826 2200kv Turnigy motor ... but with a 5x5 prop ... I'm hoping to stick a 4S into this one ...
Funny enough my 6x6 prop was just a touch big ... so I must have made slight error in tracing / cutting. No worries ... 5x5 will be fine.
Then I altered servo position ... cut slot bigger and fitted 6x6 prop ... so back to 3S but I can always swap out to 6x4 and use 4S ..
Just need a couple of screw connectors for rods and weather to improve ...
Nigel
Dec 03, 2017, 07:02 AM
solentlife's Avatar
Original G&G Mig 29 weighs in at 255gr + battery
Depron scratch version weighs in at 253gr + battery !!
I've tested the 2826 2200kv on 3S 6x6 prop and it kicks 22A
Drop back to 6x4 and she kicks 18A on 3S and 27A on 4S ... 4S 1600 weighs similar to the 3S 2200 ... so I have choice ...
The thrust on 4S is WOW !! I can't wait for weather to break and I can get out there with it !!
Nigel
Jul 01, 2018, 03:57 PM
How many degrees deflection do you suggest on the elevator and elevens?
Jul 03, 2019, 08:19 AM
MIG 29 Assembly
Good afternoon all
I am new to this game. A simple question from a new starter.
How do you glue the carbon strip to the fuselage ?
It moves every time I try
Thanks in advance
Jul 03, 2019, 09:26 AM
solentlife's Avatar
Blimey ... is it a year ago this question was raised ??
My answer should have been a lot earlier ....... to be honest .. I have no idea !! I just set it up with a lot on high rate ... about 60% on low and a lot of expo to help if it was too much.
solentlife's Avatar
Originally Posted by ikaruseci
Good afternoon all
Thanks in advance
Thick CA (foam safe is a good idea to be on safe side).
