Losi 1/10 Rock Rey 4WD RTR!
Check out the true basher from Horizon. It can take on just about anything!
A 40 MPH Basher!
The 1/10th 2.2 Rock Rey Rock Racer can it take on rocks and bash through mud and water! It can do speeds over 40 MPH and features AVC technology.
Losi 1/10 Rock Rey 4WD RTR with AVC (2 min 13 sec)
Features
  • Rock Racer chassis design
  • 3.5mm anodized aluminum chassis plate
  • Integrated roll cage
  • Dynamite 2800Kv brushless power system
  • Spektrum AVC® technology
  • Long-travel suspension
  • 4-link live rear axle
  • Waterproof electronics
Specs
  • Approximate Assembly Time: No assembly required
  • Ball Bearings:Yes
  • Batteries:2S 5000mah 30C Li-Po with EC3™ Connectors (not included)
  • Body:Screened, Polycarbonate
  • Brakes:Electronic
  • Chassis:3.5mm Plate, 6061-T6 Aluminum
  • Completion Level:Ready-To-Run
  • Differential:Locked Rear, gear diff front and rear
  • Drivetrain:4WD
  • Final Drive Ratio:32.30:1
  • Front Track:12.75 in (323.8mm)
  • Gear Pitch:1.0 Module
  • Ground Clearance:2.2 in (55.9mm) at rear diff
  • Height:8.75 in (222.3mm)
  • Length:20.75 in (527mm)
  • Model Type:Car/Truck
  • Motor Size:550 6-Pole 2800kv
  • Motor Type:Non-Sensored Brushless
  • Painted or Clear Bodies:Painted
  • Pinion:12T
  • Radio:Spektrum DX2E 2.4GHz
  • Rear Track:12.75 in (323.8mm)
  • Servos:Included
  • Shock Type:Oil-Filled/Coil-Over Spring
  • Size/Scale:1/10
  • Speed Control:Dynamite 130 Amp WP
  • Suspension:Independent Front/4-Link Rear
  • Tire Diameter:5.75 in (146mm)
  • Tire Tread:Maxxis Creeper Crawler LT
  • Track:12.75 in (323.8mm)
  • Vehicle Type:Off-Road
  • Water-Resistant:Yes
  • Weight:6.55 lb (3.0kg)
  • Wheel Diameter:2.2 in (55.9mm)
  • Wheel Hex Size:12mm Hex
  • Wheel Type:2.2 in (55.9mm) Glue-Type
  • Wheel Width:1.6 in (40.75mm)
  • Wheelbase:15.0 in (381mm)
  • Width:12.75 in (323.8mm)
  • Sealed, metal-gear transmission and diffs
  • Coil-over, oil-filled shocks
  • Easy-access battery compartment
  • Bolt-on body panels and interior details
  • Includes Spektrum DX2E transmitter with AVC adjustment
  • Bright LED light bar
Photos
Link
Visit the site for more info.
Dec 29, 2016, 05:14 PM
RCG Admin
Jason Cole's Avatar
Ooh, I like!
Dec 29, 2016, 10:38 PM
sweet losi is going to get back into rock crawlers for 3 months again. :/
Dec 30, 2016, 12:07 AM
ApexpredatorGT's Avatar
The body reminds me of those Polaris vehicles. Very cool
Dec 30, 2016, 12:24 AM
Panhead5496's Avatar
Just curious, if it's "water resistant" not water proof, why do they have a pic of it going through so much water??
Latest blog entry: Life Updates :)
Dec 30, 2016, 12:32 AM
I think they use water resistance as a means to cover their ass. People buy a water "proof" rc truck and go drive it under water like a submarine, ruin the esc or RX and then call the company for a warranty replacement.
Dec 30, 2016, 01:34 AM
40mph and it runs only a 2s battery. Or 2x2s. ..?
answering my own question. it runs on 3s as well as 2 s
Dec 30, 2016, 11:41 AM
Ah Apex that makes sense. I'm sure some people see water proof and abuse it lol
Dec 30, 2016, 02:23 PM
I assume this is on the same chassis as the Baja rey ,looks like a cool variant .Those look like the wheels of my twin hammers as well.
Dec 31, 2016, 03:41 PM
USA: LakeGeorge, New York
is this 1/8 size? but labled as 1/10?
15inch wheelbase!
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Dec 31, 2016, 07:47 PM
KE Spins make me dizzy.
It's big, it runs 2.2's... it's cool. It's kind of like the Twin Hammers' bigger brother.
Jan 02, 2017, 10:05 PM
Axial took the yeti. Changed the body and tires and made the yeti score tt. Losi took the baja rey. Changed the body and tires and made this.
Jan 04, 2017, 04:50 PM
2.2 maxxis creepy crawlers, wonder if they will make a 1.9 version?
Jan 04, 2017, 07:30 PM
it's possible if enough people want them. I'd go with proline's 2.2 chisels or maaaybe their new hyrax's
Jan 28, 2017, 06:03 PM
RIP PRo line
The big difference is Losi sells through HH, Axial sells all over. If Losi was serious about selling they wouldn't give an exclusive to HH.
