Dec 25, 2016, 07:20 AM
New Product
Feiyue FY03 Eagle-3 1/12 2.4G 4WD Desert Off-Road Truck RC Car
Description:
Specification:
Color: Green,Red
Vehicle Size: 382217cm
Package Size: 5526.121.5cm
Weight: 2.5kg
Wheel Gauge:24.7cm
Wheelbase: 19.3cm
Wheel Width: 3cm
Tire Diameter: 4.5cm
Front and Rear Wheel Minimum Distance: Around 15cm
Motor: 390 High-Speed Motor
ESC: 40A
Battery: 7.4V 1500mAh Large Power Li-ion Battery (INCLUDED)
Frequency: 2.4Hz
Remote Control Distance: ≥80m
Use time: Around 15 minutes
Charge time: Around 2.5 hours
Remote Controller Battery: 4 X 1.5V AA Batteries (NOT INCLUDED)
Speed: ≥35km/h
Protection Performance:
1.Charge Protection: Overcharge Protection of Lithium-ion
2.Low Voltage Protection: Receiver stop working when batteries voltage is lower than 6.5V
3.High-Temperature Protection: When receiver working temperature is higher than the pre-set temperature, receiver will protect
drive and control circuitry and work again after cooling down to the pre-set temperature.
Features:
1. 1500mAh Large Power Li-ion Battery
2. 2.4G 2CH Full Scale Synchronous RC System
3. 19g High-Speed Servo (1kg Torque Force)
4.Front Wheel Twisting-Axle-Type Shock Absorbing Independent Suspension System, Rear Multi-Link Suspension
5.2CH 2.4G 40A ESC
6.Metal Shock Absorbers
Brushless Version:
There are spare parts you need if you want the car speed up to around 70km/h.
Spare parts:
1.Remote control (control distance: 160M)
2.2.4 receiver
3. 3 power line servo (torque force: 2.2kg)
4. 35A Brushless ESC
5. 2838 Brushless Motor (4500kv, shaft diameter: 3.175mm)
6. 26T metal gear (Φ3.2mm)
Package Included:
1 X Car Body Shell
1 X Car Model
1 X Transmitter
1 X Charger
1 X Manual
Dec 28, 2016, 01:32 PM
If you need any tips or upgrade options there are several long threads on this car already on this forum .
Dec 28, 2016, 08:49 PM
yes, but none that have linked back to where he sells it from before this.
Dec 31, 2016, 04:54 AM
I think it's spam pretty much, it's different if a member spots a good deal and shares a link but this is just an advert.
Dec 31, 2016, 06:08 AM
yep, but at least with this thread he went to the effort of copy and paste some details, unlike his other threads where he just puts in a hot link.
