Jul 25, 2018, 03:43 AM
I have the HSD Super Viper ECO version with Swiwin 60B turbine.
The ECO version is little cheaper. I comes without smoke system and no lights.
The first 50 planes were sold by HSD end of last year at reduced price.
I was lucky to get one of those... at $2000! (turbine included)
This is my first turbine plane and I'm very pleased with it!
Easy flying plane.
I have 12 flights on the plane now.
Only issue I had were the JP brakes. The brake force between both wheels was way out of balance.
Had to install new set of brakes and all perfect now.
Originally Posted by Tronn
Are you pleased with yours? Would you buy another one today?
Jul 25, 2018, 03:52 AM
Wow $2,000! That was a real bargain. Well done!
Can you recommend where I should purchase one?
Jul 25, 2018, 04:30 AM
I purchased straight from HSD China.
$300 shipping and $200 taxes. So total of $2500 but still very good price.
Not sure if there is a dealer in Australia...
Check following sites and ask for shippingcosts
www.hsdgo.com
www.hsdjets.com
Jul 25, 2018, 08:49 AM
"In Thrust I Trust"
Desert Fox's Avatar
Tronn,
The kit versions require the following taken from HSDGO website.
REQUIRES:
6+ channel radio system(radio & receiver)
2S 7.4V 2000mAh LiPo with T type connector(UBEC)
3S 11.1V 2000mAh LiPo with XT60 type connector(Turbine Engine)
LiPo battery charger
Landing gear
UBEC
Servos
Turbine Engine
General landing gear control system
Integrated mix-control system
All wire
Tail nozzle
Tank
Also brake system, UAT.
Cheers!
Desert Fox
Jul 25, 2018, 12:52 PM
kero burner
jdlilfan's Avatar
I am looking at buying one of these.
Does anybody know what is included in the turbine kit?
https://www.aliexpress.com/item/2017...808458169.html
just foam, plywood, and maybe the pipe (not sure). No gear, electronics, servos, etc. I'm not sure if the tanks are included either. I think they might be.
Jul 25, 2018, 04:46 PM
I got back confirmation no pipe is included either.
So it looks like around $800 for a bare foamy no landing gear, electronics, pipe, tank or anything?
That is one very expensive piece of foam??
I can buy a Sebart Mini Avanti for that much money and it comes with a composite fuse and retracts?
Wouldn't that be a better purchase?
Jul 25, 2018, 04:47 PM
Quest for Speed!!!
Mike_eee's Avatar
I think for 999 you can get the economy version all ready to go minus turbine and radio stuff
Jul 25, 2018, 04:51 PM
Thanks Mike, do you know where I can get that from?
On that AliExpress page there is no economy version.
It just goes from the kit version which is $850 Australian then up to $2,350Australian for the plug and play version which has no turbine.
Jul 25, 2018, 06:42 PM
Quest for Speed!!!
Mike_eee's Avatar
Here you go
https://www.hsdgo.com/hsdjets-super-...rbine-blue-pnp
Jul 25, 2018, 07:03 PM
Awesome, thanks Mike. Do you have one of these? Have you flown it much?
Would you recommend it?
Jul 26, 2018, 04:34 AM
The Eco version is the perfect choice for starting in jets.
Aug 03, 2018, 12:52 PM
chopper52's Avatar
Smoke Tank
Hey
Can one of you tell me how much the smoke tank holds in fuel......Thanks....
Aug 03, 2018, 01:22 PM
"In Thrust I Trust"
Desert Fox's Avatar
chopper52,
The smoke tank is molded with 750 cc on it. That is the same as 750 ml which equals 25.3605 ounces.
Cheers!
Desert Fox
Aug 04, 2018, 05:03 AM
Could you use the smoke tank for extra fuel?
Aug 04, 2018, 05:13 AM
Quest for Speed!!!
Mike_eee's Avatar
Yes you can .. stock tank on K60 gives 5 mins of mixed flying and 2-3 go arounds to land...by then ur in the UAT tank draining fuel.
plumbing the stock smoke tank may give u additional 3 mintues of flight ... so 5+3 minutes of flying time.
Discussion Just received HSD v3 Navy turbine super viper fly baby Large EDF Jets 2 Dec 22, 2016 10:57 PM
