RedRotor RROSD V2 - RC Groups
Dec 18, 2016, 06:31 PM
New Product
RedRotor RROSD V2
The 1 year old RROSD Pro V1 now has a brother…RROSD PRO V2!
Download RROSD V2 User Manual
FEATURES:
  • Dimension 36mmx36mm (30.5mmx30.5mm mounting holes)
  • Maximum motor current 150A total
  • Built-in power distribution and regulators to handle 2s-6s *note1
  • Noise free output without external capacitor *note2
  • ​ 10V and 5V output: can be used for VTX/FPV cam and accessories
  • NTSC and PAL can be easily selected using the onboard button
  • Plug and Play (PnP) OSD information: Flight pack voltage, current draw, total current consumption, RSSI, flight timer
  • Statistic page after landing
  • Automatic flight timer shows actual flight time
  • Buzzer: after 5 minutes of inactivity, low rssi
  • Auto RSSI detection (FRsky and analog compatible), displays in percentage
  • Battery pack alarm feature blinks the battery voltage when pack voltage hits the set limit
  • Onscreen menu allows user to set rssi input, calibrate current sensor, set battery capacity alarm…etc....
*note1 - Maximum current draw on 10V rail: 400mA @3s/4s, 250mA @5s, 150mA @6s
*note2 - External capacitor might be needed when vtx solder bridge is set to RAW
Where can I order one?
http://www.redrotorrc.com/index.php?...product_id=121
Distributors:
USA
http://www.readymaderc.com/store/
http://pirofliprc.com/RROSD-PRO-V2_p_3705.html
http://www.heli-nation.com/redrotor-...ribution-board
https://www.fpvheadquarters.com/redrotor-rrosd-pro.html
https://skywardrc.com/products/rrosd-pro-v2
RROSD Pro V2 Test || FPV Freestyle (2 min 11 sec)
RROSD V2 Menu Walkthrough (1 min 7 sec)
Testing All the New Things // Kiss 1.1 DShot // Shendrones Prototype (2 min 17 sec)
Dec 18, 2016, 06:32 PM
reserved...
Dec 19, 2016, 02:00 PM
metropolis's Avatar
Huzzah, a new page!
I'm extremely happy with the v2 and can't wait to do more builds with it in the future!
Here are some of my pictures and videos with the V2:
Kratos First Session Flight (3 min 42 sec)
The following two were test flights
RROSC v2 f2 (4 min 3 sec)
RROSD V2 First Flight (3 min 32 sec)
Dec 19, 2016, 10:49 PM
I crush you
PinchTune's Avatar
I see the text is bigger in the V2. I have 3 or 4 V1s and I love them, except for the pad layout. I hate shared pads, so this one is a breath of fresh air. I don't like or need the bigger text, but I don't mind it too much and I can see it being good for a lot of people. Think I might preorder one or two.
Dec 20, 2016, 01:49 AM
Totally love the new form factor. The corner solder pads are awesome and how cool that they are on top and bottom. You could run this board inverted if you needed the flat side up for more wiring room or to run low profile pins. Here are a few pics of our first build with it. Haven't flown it yet but love it so far, allows some really compact builds.
Kevin
Dec 20, 2016, 03:31 AM
So I can't use this with tbs unify pro hv?
Dec 20, 2016, 05:30 AM
You can, just set VTX voltage to RAW/VCC
Dec 20, 2016, 10:03 AM
Will this new version phase out the lap timer then? Personally, I'm a big fan of that lap timer.
Dec 20, 2016, 11:43 AM
Originally Posted by metropolis
Huzzah, a new page!
Thanks for sharing the build pics and videos J!
Kevin
Looks like a really nice compact build Kevin. Don't forget to share videos when you have a chance to let it rip
We use this exact vtx on 3s/4s/5s ...just make sure you don't exceed the current rating of the rrosd when solder bridge is set to 10v. We have been flying ours on 25mw - 400mw with great video
Sadly the lap timer feature isn't available for now. The hardware was designed for it but it's not available in the current firmware.
Dec 21, 2016, 03:42 PM
back in stock
RROSD V2 are back in stock! all pre-orders will be shipped by tomorrow...Thanks guys!
Dec 21, 2016, 05:30 PM
I crush you
PinchTune's Avatar
Just chiming in to note I pre-ordered one a few nights ago. Same night I posted my first comment a few posts up the page. I intend to do a little video about it on my YouTuBe channel (@Pinchtune) once I get it. It'll likely be an overview about it and what I think of it compare to the V1.
Dec 22, 2016, 07:51 AM
Chargerdude70's Avatar
Ordered on the 15th and received on the 20th. Thank you bt408.
Dec 22, 2016, 08:00 AM
Mine are at customs, 4 days from USA to Europe. That's fast. Tomorrow should have it.
Love RROSD.
Dec 22, 2016, 09:00 AM
metropolis's Avatar
You guys are going to love your v2's! I love mine!
Dec 22, 2016, 09:42 AM
Love RROSD.
Mine is at costums as well. Should have it tomorrow too
