This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Dec 18, 2016, 04:27 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-HowTo
DJI Phantom 4 Advanced & PRO Update Information -Known Issues - Troubleshooting
DJI Phantom 4 Advanced & PRO Firmware Update - Troubleshooting and common Issue Information Updated
The Phantom 4 Advanced & Pro is available from DJI
If you would like to support me you can choose to order from DJI via the below links
The Phantom 4 Advanced http://click.dji.com/AD6pQdh5pOTQ8AI...m=link&as=0002
The Phantom 4 Pro http://click.dji.com/ACAG0tVcbVw91cs...m=link&as=0002
Note: As with all my own blog post all links may be affiliate links and i will receive a small commission on any purchase bought through them , if you wish to support me then thank you however it is not expected .
Latest FW versions
Phantom 4 Advanced
Date : 08/06/2017
Aircraft Firmware : V01.00.0128
Phantom 4 Adv Remote Controller Firmware : V2.1.1.0
Phantom 4 Adv + Remote Controller Firmware : V1.2.0.0
Phantom 4 Pro
Date : 08/06/2017
Aircraft Firmware : V01.04.0602
Phantom 4 Pro Remote Controller Firmware : V1.4.1.0
Phantom 4 Pro+ Remote Controller Firmware : V 1.2.0.0
KNOWN ISSUES AFTER THIS UPDATE
NO CONNECTION BETWEEN RC & CRAFT AFTER UPDATE
Rebind RC to Craft as per the DJI Manual or the Video below on this blog
NO MAPS OR MAPS INT ERROR ON PLUS RC
Perform a full factory reset from the Plus RC and the maps will return.
SMART RTH SWITCH & HDMI OSD OPTION MISSING
These are currently missing from the latest release - Currently no more info.
GEO NFZ NOT UNLOCKING
Have seen a number of reports of users not being able to unlock Yellow zones on this latest FW, reports are sporadic but if you are having this issue I would suggest a full FW refresh and Delete DJI Go, Reboot your device and download again.
CURRENT KNOWN ISSUES
4K 60fps FRAME DROPPING ISSUE - RESOLVED
There was a known issue with 1080P 60FPS where its adding frames randomly in recordings this only affected the 4K 60FPS recording mode .
RESOLUTION
This was resolved with firmware V01.03.0418
3rd PARTY APP ISSUES WITH FIRMWARE - RESOLVED
There was an issue introduced with firmware V 01.03.0418 that could cause erratic behaviour when used with 3rd party apps such as Autopilot and Litchi, All the 3rd part app providers sent out a warning to say to downgrade to if you wanted to continue to use them, This issues affect the Mavic, Phantom 4 Pro and Inspire 2.
RESOLUTION
Firmware version V01.03.0418 resolves this issue.
PHANTOM 4 PRO+ CRASHING AND BAD FEED - RESOLVED
There was a known issue with the Plus RC with integrated Android system that it is crashing and giving poor performance in general, Live feed glitching ect.
RESOLUTION
Firmware V 1.1.3.0 fixes this issue, , IF you do its worth checking if your RC fan is working, you should be able to hear this after a few minutes, overheating could also be a cause of this issue, none running fans is a HW issue and would beed to be sent into DJI for repair.
GIMBAL HORIZON ISSUES - RESOLVED LATEST FW
A number of users have reported very bad gimbal performance especially since installing the latest Aircraft Firmware V 01.01.0203.
RESOLUTION
This appears to have been resolved with the latest firmware.
If this does not help its advised to try a number of cold IMU calibrations followed by gimbal calibrations otherwise you may need to send it into DJI for repair.
HDMI BOARD NOT WORKING GL300F
The HDMI board from the P3 and P4 is compatible with the GL300F RC with the device holder some users have not been able to get it to work straight away.
RESOLUTION
If after installing the new HDMI board it does not work and it did not prompt for an update try the following
Install the original USB board
Downgrade the RC firmware to the last version via the Go App - Process here Phantom 4 Info with RC FW Downgrade
Install the HDMI board again and you should be prompted for FW update, follow process and it then should work
ADDITIONAL INFORMATION
GL300E vs GL300F REMOTE CONTROLLERS
The Phantom 4 Pro is available with 2 different remote controllers.
The GL300F
This is the traditional looking remote with the device holder on the top, USB port as standard on the rear.
This RC is not compatible with the Phantom 4 and does not come with HDMI as standard.
The GL300E
This is the traditional looking remote but with a builtin high contrast smart device, this inbuilt screen runs on android OS, is not removable and has a specific version of DJI Go 4 App, On the rear it has a USB port,HDMI and Micro SD card slot, it has built in Wifi and can connected to your smartphone or WIF network for updating the firmware or caching the maps.
This RC is also not compatible with the Phantom 4, , there are also some other limitations around 3rd party apps as well explained further below.
DJI Go & DJI Go 4
DJI has branched off its Go app into 2 versions, from this point forwards you should use the correct app for your model.
Use DJI Go V3x for the following products
Phantom 3 Series
M100/M600/LB2
Use DJI Go 4x for the following products
Phantom 4 Series including the P4 Pro
Mavic Pro
Spark
Inspire 2
FAQ
CAN I USE 3RD PARTY APPS WITH THE GL300E WITH INTEGRATED DEVICE
Currently No, the only app thats compatible and installed is a custom version of DJI Go 4, this may change in the future as its base OS is android as DJI may open it up to the SDK or someone may find away around it.
CAN I USE EXTERNAL TABLET WITH THE GL300E WITH INTEGRATED SMART DEVICE
Currently no ,the USB port is not active and there is no way to disable the integrated smart device
CAN I USE THE GL300E WITH INTEGRATED SMART DEVICE WITH THE PHANTOM 4 (NOT PRO)
No they uses a different wireless Lightbridge system, The Advance and Pro RC's are believed to be compatible through.
CAN I USE THE P3/4 HDMI BOARD WITH THE GL300F RC
Yes the DJI HDMI Board is compatible - See troubleshooting for additional notes
IS THE IMU CALIBRATION THE SAME AS THE PHANTOM 4 AND DO I NEED TO DO ONE BEFORE I FLY FOR THE FIRST TIME ?
DJI state you do not need to calibrate the IMU out the box as this is done at the factory under specific conditions.
DJI have moved to a new method of calibrating the IMU with the P4 Pro as they did with the Mavic Pro, If you do need to calibrate the IMU you should cool the craft to as cold as possible before hand then follow the onscreen in prompts to rotate the craft through each axis, again always perform on a perfectly level surface.
FIRMWARE UPDATE PROCESS
Updating the Craft via DJI Assistant 2 App PC/MAC
There are 2 ways to update the Phantom 4 Pro craft, the first is via the Assistant 2 PC and Mac Application, this can be downloaded form the DJI website under the downloads section, the second method is via the DJI Go App, the below videos show how to perform both.
DJI Phantom 4 Pro - Upgrading Firmware (DJI Assistant 2) (1 min 44 sec)
Updating Craft and Controller via DJI GO
DJI Phantom 4 Pro - Upgrading Firmware (DJI GO 4) (1 min 47 sec)
Controller FW Downgrade Process - Not Plus RC GL300F ONLY
If you update the controller before updating the craft but can't update the via Assistant 2 for some reason you can downgrade the RC back to V1.580 as follows
Connect the controller to the Tablet and turn on
On the DJI Go home screen press and hold the Academy (little hat) icon in the top RH corner, you will need to hold this for at least 10 seconds and when you release you should get the below screen
This will allow you to select the last FW version and downgrade the controller allowing you to reconnect.
GENERAL ISSUES and TROUBLESHOOTING
Object Avoidance System Errors or Poor Performance
If your having poor altitude hold or are getting avoidance system errors perform a calibration of the avoidance system cameras as follows
Phantom 4 Tutorials - Calibrating the Vision Positioning System (3 min 22 sec)
Locate Update Log File
To check if your update has been successful or provide DJI with further details
Phantom 4 Tutorials – Finding an Upgrade LOG File (1 min 52 sec)
Link Phantom 4 Pro RC
DJI Phantom 4 Pro - Linking the Remote Controller (1 min 48 sec)
Installing HDMI Board on Phantom 4 PRO GL300F RC
This is the same identical process as on the Phantom 3 Advance and Pro
Phantom 3 Tutorials- How to install HDMI Output Module on Phantom 3 Remote Controller (4 min 29 sec)
Poor Range and Signal
Make sure you are correctly orientating the antennas when flying
DJI Tutorials - Remote Controller Antenna Best Practices (3 min 22 sec)
Poor Live Feed, Brake Up, Live Feed Dropouts
If your getting No signal, Poor live feed, Dropouts and overall poor Lightbridge connection issues try the following
Resolution:
Replace SD Card with another, A bad SD card can cause Live feed problems
Try custom channel setting and set to a clear channel and set to 4mbps
Try installing the channel mod and using custom channel on a clear channel out of the normal band
MORE INFORMATION
The New DJI Phantom 4 Advanced Released
The DJI Phantom 4 Pro A Worthy Upgrade
My DJI Mavic Pro Update Information -Known Issues - Troubleshooting Blog
My DJI Phantom 4 FW Update Information -Known Issues - Troubleshooting Blog
My DJI Phantom 3 Adv/Pro FW Update Information -Known Issues - Troubleshooting Blog
Apr 14, 2017, 05:37 AM
Updated and tidied up
Jun 10, 2017, 03:09 AM
Updated to Latest Info for current models and firmware
