1/4 Scale Sig Morrisey Bravo Build - RC Groups
Dec 14, 2016, 12:30 AM
teufelhund222's Avatar
This is a vintage kit long OOP from Sig. It's a kit I'm building for a fellow RCG member. Let's get started! Pics here are of the kit pieces being sorted and relevant parts for each area of the fuselage, wings, and tailfeathers, along with the FG parts and LG. The wing parts after being cleaned up and dry fitted before assembly. Sig must have cut down a small balsa as well as a spruce/pine forest to kit these!
Dec 14, 2016, 01:39 PM
Pro Hoarder
turbonut's Avatar
Nice, There is a full scale near by I see often
Dec 14, 2016, 03:00 PM
Nice turbonut! Can you get any pics of it? I've never seen a full scale one anywhere outside a magazine.
Dec 14, 2016, 04:29 PM
Pro Hoarder
turbonut's Avatar
I will see if I have any..
Dec 14, 2016, 06:09 PM
Thanks turbonut!
Dec 14, 2016, 06:35 PM
Right wing construction...
Building begins, slinging glue now. Construction begins on the right wing panel. Spar construction and inner/outer construction is a bit different from most conventional building. The wing starts out the same thickness, then around halfway it begins a double taper to the tip. I hope the pictures show what I'm talking about.
Dec 14, 2016, 08:02 PM
Pro Hoarder
turbonut's Avatar
If you look close you can see it in this vid.
Fun in the So Cal Desert 2016 (0 min 26 sec)
Mine is the bare metal Cessna
Dec 14, 2016, 08:25 PM
I caught it! Wow! That would be so cool to fly out to and camp. Lot's of fun!
Dec 14, 2016, 08:27 PM
What model Cessna is yours? I thought it looked like a 150? I thought I spotted a Luscombe Silveraire also?
Dec 15, 2016, 12:54 AM
Pro Hoarder
turbonut's Avatar
Mine is a 1958 175 with a 230 hp o-470 motor. its at the end of the Vid. No luscombe. But 3 Bear Hawks and 2 Aeronca Chief. Plane camping is the best!
Dec 15, 2016, 02:58 AM
I'm green right now, you really do have the life!
Dec 15, 2016, 07:15 PM
very nice build thread! I'm excited!!
Dec 15, 2016, 08:53 PM
Thanks Bobby!
