Dec 13, 2016, 05:43 AM
nitbeat's Avatar
New Product
Runcam 3S - New Version
Runcam HD camera is back with a new version called: Runcam 3S
Runcam 3S WIFI 1080p 60fps WDR 160 Degree FPV Action Camera Detachable Battery for RC Racing Drone
https://www.banggood.com/Runcam-3S-WIFI-1080p-60fps-WDR-160-Degree-FPV-Action-Camera-Detachable-Battery-for-RC-Racing-Drone-p-1338456.html
Specification:
Brand: Runcam
Item name: RunCam 3S sport camera
Video Resolution: [email protected] / [email protected] / [email protected] / [email protected]
Video File Format: MOV
Image Resolution: 2MP
AV Output Format: NTSC / PAL Switchable
Communication Interface: Micro USB
microSD card supported: 64G max
Battery Capacity: 850mAh
USB Power Input: DC 5-15V
Power Consumption: 620mA @5V
Dimension: 40*38*36mm
Net Weight: 69g (with battery)
Features:
-1080p/60fps Video
-160 Wide Angle
-Lens Protection
-RFI Shielding
-Support Wi-Fi
-Designed for Racing(FPV)
-Optimized 13 inner structures, compared with RunCam 3
-Battery is replaceable, releasing you from power trouble.
-Excellent WDR Effect:
ensuring high-quality image even facing directly to the sunlight
Package included:
1 x Runcam 3s camera
1 x Micro-USB TV-out and power cable
1 x Micro-USB cable
1 x Battery
1 x Manual
2 x Velcr o
manual: RunCam-3S-Manual-EN.pdf
UPDATE - Runcam 3 isn't available currently for purchase, the alternative for now is the new Foxeer BOX HD camera
159$ until January 7.
FOXEER Box 4K
FOXEER Box 4K CMOS FOV 155 Degree Micro Bluetooth WiFi Camera Mini FPV Sport Action Cam
http://www.banggood.com/FOXEER-Box-4K-CMOS-FOV-155-Degree-Micro-Bluetooth-WiFi-Camera-Mini-FPV-Sport-Action-Cam-p-1136301.html
Runcam has released their new and exciting CUBE HD FPV Camera the Runcam 3 (Similar to the Session and Polaroid Cube Design)
UPDATE - Banggood has just listed the new Runcam 3 HD
RunCam 3 64G HD 1080p/60fps NTSC/PAL 155 Degree Wide Angle WiFi FPV Camera
http://www.banggood.com/RunCam-3-64G-HD-1080p60fps-NTSCPAL-155-Degree-Wide-Angle-WiFi-FPV-Camera-p-1127476.html
In this thread we'll talk about updates regarding the up and coming Runcam 3,
Key Features
  • Higher FOV (155)
  • Light weight - 66g
  • Lens protection for FPV
Runcam 3 vs. Session 5 Video
Runcam 3 (1 min 39 sec)
Runcam 3 VS Session 5 (1 min 15 sec)
Accessories
http://www.banggood.com/search/runcam-3.html
..............Waterproof Case.................................................. ...Open Case.................................................. ....Glass Protector
3D Printed 30 Degree Gopro Session Runcam 3 Camera Fixed Mount
http://www.banggood.com/3D-Printed-30-Degree-Gopro-Session-Camera-Fixed-Mount-Holder-for-FPV-Racer-p-1102560.html
Info From Product Page
Specification
Brand: RunCam
Weight: 66g
Video Files: MOV
WDR: ON / OFF
TV Output: NTSC / PAL
USB Power Input: DC 5V-17V
Working Current: 600 mA
FOV(Angle of Field): 155
Image Resolution: 2 megapixels
Image Flip(Manual/Auto) : 180 Rotation
Dimension: 38mm(L) * 37.5mm(W) * 38mm(H)
Video Resolution: [email protected] / [email protected] [email protected] / [email protected]
Max Micro SD Card Supported: 64G(need class 6 or above)
Battery Capacity: 960mAh(1.5h @1080P 30fps / 1h @1080P 60fps)
Features
Exceptional WDR
Exceptional WDR algorithm allows no darkness under the sun
155 Wide angle & Smooth video in 1080p/60fps
6 Glass lens with 155 wide angle,Runcam 3 can Capture 1080P/60fps high definition video
Stronger lens protection
6000 Series high strength aluminum alloy front box
Corning gorilla glass 3
* Glass can be replaced, sold separately as a spare part
Ideal form factor for FPV
Small cube size 38mm (L) * 37.5mm (W) * 38mm (H)
suitable for a variety of quadcopter frames
Special protective cover for FPV
Included silicone mount: stronger protection and easier to install
High sensitivity dual microphone
High sensitivity dual microphone + independent audio chip: for clearer sound recording
Unique * RFI shielding enclosures
Effectively reduce RF interference to transmitter and receiver
* RFI: Radio Frequency Interference
Also an action camera
Compatible with various brackets* of the GoPro Session, RunCam 3 can also be your action camera.
*Recommend RunCam's border protection and waterproof shell, more perfect match
nitbeat's Avatar
FOXEER Box 4K vs. Runcam 3
This is the war of the low-cost CUBE HD FPV Camera's.
Runcam 3 is now leading in terms of availability, but the FOXEER Box 4K seems to have better specs and super view feature,
which is IMO very important.
Comparison Table
FOXEER Box 4K
http://www.gearbest.com/camera/pp_617166.html
Description :
Brand Name : Foxeer
Item Name : Box 4K Camera
Sensor: IMX117 CMOS
Lens: 155 degree FOV
Connectivity: WiFi + Bluetooth
Interface: micro USB HDMI
Lens protection glass: yes
Stereo microphone: yes
Display: OLED
Waterproof level: IP64
Image stabilization: EIS
Video format: H.264 codec,mp4
Resolution:4K30fps/2.5K60fps/1080P120fps/720P240fps/4K25fps SuperVision/2.7K30fps SuperVision/1080P60fps SuperVision/720P120fps
ISO range: Auto,100, 200, 400, 800, 1600
Shutter speed: 1/30 - 1/60
EV compensation: -2.0 to 2.0
Size : 4 x 4 x 4cm
Battery: 1100Mah (irremovable)
Weight : 70g
Runcam 3 HD
Specification:
Brand: RunCam
Weight: 66g
Video Files: MOV
WDR: ON / OFF
Dec 13, 2016, 06:16 AM
nitbeat's Avatar
Reserved...
Dec 13, 2016, 07:34 AM
ɹǝʎlℲ ΛԀℲ
MarkDeLo's Avatar
Very cool! Looking forward to seeing the remaining specs. Resolution, FOV, size, weight, etc...
Dec 13, 2016, 07:36 AM
tonnoz's Avatar
Is this just a rumor or Runcam is planning to build this model?
Dec 13, 2016, 08:17 AM
sharonx's Avatar
Looks interesting, I really hope the FOV will be bigger.
subbed...
Dec 13, 2016, 08:55 AM
Thanks for the invite to the post. This Cam looks awesome....Hope the price is right!
Dec 13, 2016, 09:48 AM
SilverLine's Avatar
Form factor like the Gopro session, would be so nice. Subbed to this thread :-)
Dec 13, 2016, 04:57 PM
nitbeat's Avatar
subbed...
NEW Update
Specification
Brand: RunCam
Weight: 66g
Video Files: MOV
WDR: ON / OFF
Features
Exceptional WDR
Dec 13, 2016, 05:18 PM
SilverLine's Avatar
Looking forward to a better picture :-)
Dec 14, 2016, 03:05 AM
Nope, I don't want a higher FOV, I don't understand this desire...
You don't use the camera video output for FPV to justify this need for wider coverage.
The permanent bending of horizon when level goes up and down give me headaches... anything that is not rectilinear lens is excluded. And this mean maximum 90 degrees FOV, look what are pros using
V2 is not as old to justify replacement, competition has nothing superior in the pipe, shooting now a new model on the market will be a lost bullet.
These are just marketing hypes, driven by consumerism thinking, asking permanently for something new.
Dec 14, 2016, 05:24 AM
nitbeat's Avatar
I can't disagree more regarding the FOV, especially when looking at videos of fast flight and freestyle.
The lower FOV of the runcam 2 produces much less attractive videos than the Xiomi, gopro or any other higher FOV camera.
I looked at hundreds of different videos, and obviously my videos and its extremely different.
To the point where the same flying skills doesn't look the same, even I dare to say that
higher FOV makes your video looks more smooth, fast and professional.
I think just the opposite the "zoomed in" effect of lower FOV is more annoying to me..
Dec 14, 2016, 06:46 AM
SilverLine's Avatar
+1 on that. As a action cam, we need wider FOV
Dec 14, 2016, 06:49 AM
Vids: YouTube.com/FyreSG
FyreSG's Avatar
+1 for wide FoV.
Dec 14, 2016, 09:15 AM
Probably that's why Firefly Q6 beats everything now, due to lower FOV lens
Please don't compare the need for adrenalin pumping of racers, where probably horizon bending up and down contribute to the difficulty of flight, with the real sensation of 1:1 flight that FPV was supposedly created for...
