Dec 08, 2016, 10:43 AM
Question
Do 18650 batteries need to be balance charge when charging for the first time?
If you have 6 18650s and they are all around 30-40% charged out of the box do I need to balance charge them or charge each of them separately (instead of a 3s2p connection) for the first time?
Dec 08, 2016, 11:38 AM
Balance charging is sufficient.
Dec 08, 2016, 08:45 PM
What if I charge each cell individually?
Dec 08, 2016, 08:56 PM
If done on the same charger indivisually the voltage should terminate the same making them balanced.
Dec 08, 2016, 08:57 PM
no to individually charged .. yes to 6 cells as a pac
Dec 08, 2016, 09:35 PM
So if I make a 3s2p pack and charge them as normal for the first time it would be ok?
Dec 08, 2016, 09:41 PM
If it flies, I can crash it.
rocketsled666's Avatar
Balance charging is essentially the same as charging the cells individually. There is no difference in the outcome if you charge one at a time or balance charge a pack. The only difference is how long it takes and the degree of PITA factor.
