Thread Tools |
This thread is privately moderated by glassfox, who may elect to delete unwanted replies. |
Insight 5.8G 1080P 100mW Full HD Digital Video Transmission System
-1080P HD
- Over 5km distance with the 14db directional antenna(custom) -Buit-in OSD -Transmitter weight 58g only -USD 249.99 freeshipping Can you believe it? Isn't it a lovely baby?! Check out more information in the video. And grab one for yourself: https://www.foxtechfpv.com/insight.html
Latest blog entry: Foxtech Five Oblique Aerial Cameras...
Features:
5G FHD Digital video transmission Input support up to 1920*1080@60fps,Output support up to 1920*1080@30fps; Use the 5G radio technology, TX power 100mw(CE certification and FCC certification); Ground control with the 5db omnidirectional antenna (standard),transmission distance over 2-3 km; Ground control with the 14db directional antenna(custom), transmission distance over 5km; Input and Output: HDMI Input 5G WI-FI FHD Output: Android phone, Pad can be used as a monitor after connected the APP. Anti-interference Up link/Down link Using MIMO multi antenna technology and OFDM modulation mode, with advanced algorithms, and effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system; Down link real-time monitoring of each channel interference state, dynamic selection of optimal channel work (up to 24 transmission channels); supporting up to 24 devices working at the same time; Low latency System maximum time delay 80ms; OSD function Built in OSD function, you can achieve the information function with the APM pixw pix without the external OSD. Bundled flight controller Without any restrictions on the APM pixw APP pix built-in digital transmission. Multiple mode and information secure Ground side can link over two devices. To ensure that information only through the ground side of the authorized frequency of the encryption transmission video data can be received. Battery and charge Ground side built-in 1300mAh large capacity battery, the device can work continuously for 2 hours, can be charged by power bank. Sky control input voltage 5-18V Product specification Video input: HDMI Support format(HDMI):720P 50fps;720P 60fps;1080I 50fps;1080I 60fps;1080P 25fps;1080P 30fps;1080P 50fps;1080P 60fps; RF parameters: 5GHz,FCC certification Interface(Ground control):LED, power switch, charge input, USB 2.0 Interface(Sky control):LED;HDMI input;PWM output;TTL transmission; Material:Aluminum alloy Power (Ground control)C 5v; Build-in battery; Watts: 6W Power (Sky control): DC 5~18V; Watts: 8W Size (Ground control): 69*49*16(mm) Size (Sky control): 67*37*20(mm) Weight (Ground control): 100g Weight (Sky control): 70g Transmission distance(outdoor): with the 5db omnidirectional antenna(standard),transmission distance over 2-3 km, with the 14db directional antenna(custom),transmission distance over 5km Output delay:80ms/0.08s Band frequency:5.1GHz-5.8GHz Modulation mode:MIMO-OFDM Video input:Mini HDMI Compatible input video format:HDMI all format, up to 1920*1080P@60 Output format:640*480p@30@60,1280*720p@30@60,1920*1080p@3 0 Compression:HEVC High definition television broadcasting Channels:24 channels(Automatic frequency hopping, anti-jamming) Support devices:Phone,Pad,PC Support system:Android,ios,Windows Data interface:UART data transmission interface PWM control interface:4 PWM control output, you can control the gimbal and other external devices. Communication encryption:256bit encryption Temperature:-10℃-60℃ Certification:FCC Certification |
The price seems good, your guys have a TL1000 VTX kit right? It have a longer distance for about 10KM? TL1000 10km=$4100, Insight 5KM=$300? It seems a lot of saving???
